Please help...no clue on wheels/tires?
I have no clue what offset is or what diff numbers on tires mean but I am looking to get new rims and tires. Here is what I want and maybe someone can help me out. I have a stock xB and am NOT going to lower it. I just want to get some 16's without any rubbing or rough ride. I would like a nice looking size tire on the rim though but not a real low profile. Can someone tell me what ideal rim size like lug and offest to look for and what tire size to llok for as well. Like I said I just want a 16 inch rim with a basic tire no low low profile and its NOT getting lowered. Thanks for anyhelp guys.
Like I said I read the sticky and still am very dumb when it comes to wheels and tires. I found the specs to the wheels I like and am wondering if someone can help.
Here is my goal again:
Here is the wheel measurement: 16X7 4-100/114 42
What would I need to make this sit somewhat flush with the sides of the xB?
Can someone match up a nice size tire that isn't too low profile but not a n ugly look that would still ride nice. Thank alll.
42 offset will look very sunken. Like pandaist said, get the rear spacer shims from Van at OneTonGarage: http://onetongarage.com/products/rea...him/index.html
That will add almost 10mm to the rear .
As for tires, it looks like people are running 205/40 to a 205/55, with someone with a 7.5 width running a 215. The first number refers to the width, the 2nd the sidewall height - the lower the number the lower the profile.
Hope that helps...
The front has a wider track than the rear. If you need more in the front, you can use wheel spacers. You can probably run a 3mm OK, more than that and you'll need to get longer wheel studs. Same goes for the rear if you need more than the shims.
jimsxb
08-06-2004 06:33 PM
