solve this RIM/TIRE/OFFSET equation... rim masters :)
heres the variables = you give me the missing answer
18" rim .... 7.5 width
OTG rear shim spacers
215 40 18 tires
goldline springs
thing i need answered ...
what OFFSET for my rims so that i dont have any rubbing issues when i have the OTG rear shim and springs installed.. i want the rear flush with the fender
thanx a ton guys
215 40 18 tires
goldline springs
thanx a ton guys
Originally Posted by Bull
+25-30 should be a good offset that'll get you flush (or close to it) front and rear without rubbing issues.
i need to know what offset to use taking into account ill be using the OTG rear shim spacers
thanx for the reply though ...
Tom, if the wheels are 7.5 inches wide, you can definitely run a +42 offset and not worry about rubbing. The only problem I had before the OTG spacers were I needed a 3mm spacer for the back wheels. I know, that's what offset my wheels are, and when I added the OTG spacers everything was fine. NIce and flush. OH, and I'm on at least a 2.5 inch drop.
Originally Posted by Soon2BxB
thanx man
and the 215 40 tires should work perfect with this combo right ?
thanx
thanx
thanx man
thanx
thanx
i def want a 215 40 .. i wont use a 35 because of the roads around here
heres something else to toss into the mix
a wheel i was looking at .. only comes in 18x7.5 with a +45 offset... i assume with the OTG rear shim spacers the back will be fine
but what about the front ? would i need a 3 mm spacer in the front to prevent rubbing or would a 45 offset in the front dropped on goldlines work ?
thanx again
thanx man
thanx
thanx
thanx again
I have 7.5" wide +32 offset and 15mm H&R wheels spacers and if you look down from over the fender the wheel sits perfectly flush. The front is also 7.5" wide with a +32 offset but im using olny 5mm H&R wheel spacers and they are pretty damn flush.
The only thing with the 15mm rear wheel spacer is you have to use the Extended Wheel Studs H&R give you. But the look is AMAZING! Ill have pics up of the setup tomorrow!
Why don't you just get the proper offset wheels and skip the shims? 18x7.5 (+20) front and 18x9 (+25) rear, for example. Otherwise, run the shims and go with 18x7.5 +35 all around. I've seen guys who run 18x8 and +25 with no issues, so 18x7.5 +35 with a 10mm shim should be fine.
Hey guys got my18" with 215/40 tires last week and I don't have rubbing issues. My question is if I were to drop it with goldlines will I then have any rubbing issues with these springs? If so then im thinking i'll have to with the trd's...
thanks
scion619
thanks
scion619
im running 8" wide in rear. im running a 25 offset
with about 5-7mm's of additional spacing. i can probably
swing another 2mm if i wanted to. but im pretty low to the floor,
and with 4 headsin my car.. my car is tucked.
