Spacer Fitment
Spacer Fitment
Ok, a 16x7 40mm offset wheel. Should 15mm hub spacers do the trick or should it bump up to 20? Also, would you recommend 5mm for the front or do you think it will still look good?
Music City Scions
I'm not sure about that. You should be fine but don't quote me. The tire size is the same height but slightly wider than the stock 185/60/15s. You might want to do some measuring first.
