Tire Pressure
#41
Music City Scions
Originally Posted by BoxOffice
Originally Posted by bB2NER
I'm really surprised that Toyota suggested such a low pressure? That might be part of why the EPA mpg. averages were so low.
I can start to tell the difference in ride quality at about 33-34psi, and although it definitely helps mpg, it only gets worse from there.
#42
I just put new tires on my box and I also brought it to a front in alignment shop. This guy has a great reputation and has been doing front in alignments for 40 years. He told me that I should put 40 psi in the front and 30 psi in the back. He also told me to ALWAYS get the tires rotated every 6,000 miles without fail, which I already knew. Anyway, I did what he said and I found the ride to actually be a lot better.
#43
#44
Music City Scions
How bout someone find out what the recomended tire pressures were for the bB. I'd be surprised if they were as low as the 29 psi suggested for the xB.
#45
However, as you found, you can get the car to be a bit more "neutral" cornering-wise by doing this kind of thing - though I'd be hard-pressed to run 40 on my own car - and you might even be able to induce some oversteer if you take the pressure differentials to enough of an extreme. I do this on my aftermarket tire and wheel setup, with about 36 front, 30-32 rear. It makes the car feel less like the front end is going to push out in hard cornering.
kingofthecrate
01-21-2015 09:28 PM
