View Poll Results: just a bad set of tires ????
yes?
0%
no
0%
Voters: 0. You may not vote on this poll
Tire Weat
Tire Weat
Are any others with lowered B's on 18's having any inner camber issues??? i recently bout a set of used 18's put brand new tires on them and with less than 3000 miles on them the inside edge is bald on one, and blew out on the other .. can anyone confirm there having the same issues when i had the wheels mounted i had the front end alligned and less than 3 months later now this ~
bumped any curbs? The alighnment can go out of spec, it's not set in concrete. I would have the alighnment checked again with respect to camber and toe in, you may just need some camber bolts for the front. It could be that something was left loose and the alighnment went out of spec...
some things to consider - what brand of tires did you put on? what is the wear rating on them? Are they soft sticky tires or are they are harder compond? Were the wheels properly balanced when the tires were put on? Do you make aggressive turns when driving?
If all else checks out, I would see what kind of warrenty you have on the tires, because if they are rated for longer wear, you may have to have the tire shop warrenty them. A friend of mine had some 60k tires put on his bronco, after 10k, they were bald as a baby's butt, and the tire shop replaced them free of charge due to warrenty. It's kinda hard to get tires warrentied because you are wearing them every time you drive, but "excess wear" is another story.. no tires should be bald after 3k, unless there is a severe camber / toe issue.
Before I sold my box I had 18's lowered on DF210's for about 2 years and never had an alignment done. My tires never had issues with camber or toe wear, cant think of why your tires do. Sorry I wasnt too helpful
evolving_machine
Scion xB 2nd-Gen Wheel & Tire
12
01-18-2016 08:41 PM
