What is the widest tire that will fit
Ok i want to try to squeeze a 225/40/16, or 225/45/16 on a xb, lowered with coilovers, i have seen 225/40/18, and 225/35/18 on xb's, so I belive this is possable, does any body know what fits and what off set wheel ( 16x7.5 or 16x8 ) I will need. I understand that rolling the fenders is going to be a possibility, flares maybe , but the stretched look, with wheels sticking out of the fenders is not for me.
Thanks for any help
Thanks for any help
Rolling restince of a 225 is going to be off set by the added grip. sure if I was going to add somthing like an 17, 18 or 19 inch rim then the unsprung weight would really put a dent in the performance, but i am not going for stellar fuel milage , or looks presay. A good light weight wheel with a wide tire that is inflated correctly, will not increse restance to the point of radicly reduced driveabilty , but if it is some " looks only " wheel , that weighs 20 lbs then the starting restince and unsprung weight will not add any performance at all.
Regardless of what I just said, some body out there must have tried somthing bigger than 225's , and if not, what offset did you use to stuff 225's into youe wheel wells??. any help would be great.
kingofthecrate
01-21-2015 09:28 PM
