widest rim on a tc??
what is the widest 19" rim you can put on a TC without rubbing or minimal rubbing. the reason i am asking is beacause my car is in the shop for a wide body kit and i want to get rims to sit flush with the wide fenders..thanks
how wide will the body kit put you? I know that you can fit 17X8.5 rims on the stock car. the ride with 245s is awsome. I guess this would be a matter to resolve when you know how wide the body kit will put you.
It's not so much how wide the rim can be, but how low of an offset can YOU use with the wide body. Might wanna check into the 5Axis tC. I belieive the car used 19x10's on the back. But once again it is more of a factor of offset now.
i dont really understand what an offset is? also i already have 19x8s on my car and i was just goin to get some wheel spacers to make up the difference, will that be ok?
edit: I go the kreavtiveimport 8-piece wide body kit, its about a 3 inch flare on the wheel wel
There's a difference between fitting a wheel on your car and getting one that fits properly. Offset is about the most important thing you must consider if going to a wide-body kit or even just putting on wider wheels.
Offset is the distance from the Centerline of the wheel to the wheel bolt up face (the part of the wheel that contacts the car's hub when you attach the wheel).
http://www.usacomp.com/Offset.htm
Check out this page and just do a yahoo search on wheel offset and read up on it before you order some wheels that won't fit correctly.
I fitted Fondmetal 17x7 +30 on the wifes car. Those were a one piece wheel. Nice and flush with the fender. But if you go two or three piece wheel, those fitments could be different. try a 8.5 or 9 inch wide wheel to get a lip and stretch the tire a bit to clear the fender.
8.5 in the front 9.5 in the rear, a 9 is possible on the front, but it has mad rubbing, so id stick with 8.5 being the largest
Thank you in advance for your quick reply.
on the front a 19"x8.5" +35 offset with a 225/35/19 tire clears perfect with no rubbing with a 2" drop. I have this on the front of my car so I can verify it works fine. And a 9.5" wide +40offset works on the rear, although depending on the tire size and how much you are lowered there may be some rubbing...
I am about to get some 18x8.5" on my scion what offset would work for me
and tire
225/40r18 or 235/35r18??(i think)
I like the 40 series for more meat on the rim for a better ride
so what offset guys??
35??? or what
and tire
35??? or what
and tire
35??? or what
and tire
35??? or what
