Will 205/50/17 's fit on an xB? Anyone try it?
The rims are 7'' wide rims and the car is on stock springs. You guys think I can put 205/50-17 's on them without major rubbing?
I know it's way oversized and is like +5% larger so the speedometer will be off. I'm running 17'' rims and I want to try getting a big sidewall to see if it softens the ride some.
you can put up to a 225/30/20 w/o major rubbing on stock springs
you'll be fine
*edit*
you said 205/50?... that's biiiig...i say check w/les schwab - theyve got good tire calculators
you'll be fine
*edit*
225/30-20 Diameter Difference from stock: 6.21% Circumference: 79.51"
So the 20'' Rim is about 1% larger diameter and adds almost an inch to the circumference and it also is atleast and inch wider too.
I'm about to order them so I hope that they work. My torque is probably going to go in the crapper to since the circumference is soo large and the tires are heavier.
I'm running 215/45/17 on the back with a 2 inch drop, no rubbing. I'd like to know
what tire you're running now. My 3yr old started complaining that the xb was to bouncy.For a while I concentrated only on suspension mods. If you're trying to better
the ride, I suggest monroe sensa trac shocks and sruts. They have been discussed
before, check suspension forums. Well worth the $, the monroes are stricly for a soft ride. My child no longer complains. I have the monroes with tanabe springs, it's made
a great difference. Better than stock, stock shocks are tokico kind of stiff. For the ride monroes.
Re: 205/50/17
Originally Posted by xbjoker
Unless you are trying to fill up the fender gap w/o lowering, spend the money on monroes. Cost $250.00 for about everything.
Sorry forgot to mention, our suspension is the same as echo.So if you go this route
order for the echo. You can find the #s on the forum. Fronts not so hard, you'll need a spring compressor. A tip, jack the whole front end up to get the weight off of it. If you want you can mark the struts L/R before removal, then take them to you're local shop and have them change you're springs for you. For a small fee.
So it looks like no one has actually tried this size 205/50-17 on the xB and the reason is probably because a thinner but taller tire could affect cornering and the fact that the tire is 5.31% larger than stock. But if the above quote is true, then on a stock xB, they should fit since they are smaller and thinner than the 225/30-20's.
So now, I've moved from just getting new tires, to tentitavely getting the following. My goals are to get a smoother ride, and if I can, lower my car a little without it rubbing badly. I don't mind rolling the corners.
1. Monroe Sensatrac rear shocks (#5987) and front struts (#71575)
2. H-tech springs or other springs that you guys recommended here that can lower it a little and help give a smoother ride.
3. 205/50-17 tires if I can, but I may need to lower them to 205/45-17's or stick with 215/45-17.
4. Also, my front wheels have a camber problem and the inside corners of the tires already wear out far too quickly, so what is the best way to correct this? My rims are 17x7 and use a +42 offset.
Any help or new opinions?
SpaceCaptain
05-11-2015 06:24 PM
