Aiming Sonar Halo's
Aiming Sonar Halo's
Got my halos installed, read about how to aim. Now what is happening, as I have adjusted the projectors (low) just right, the right (passenger) high is good, but the left high beam is about 10ft in front of me on the ground. Anyone know how, tricks, or is it possible to adjust "just" the high beam ???
Thanx !!
Thanx !!
I got a reply from another site, this member said he just kept playin with his and finally got it right. I adjusted mine so much it broke the silicon seal and pushed the lense from the housing. I had to deinstall, adjust both adjustment points all the way back, reseal, let set and readjust them. This is the conclusion I've come to. ......
You got 2 adjustment screws, the top inside one over the high beam is the vertical (up-down) adjustment, the bottom outside is the horizontal (left-right) adjustment. The horizontal screw not only moves left-right, it also moves the light slightly up-down. Screw being on the bottom outside of the low beam instead of halfway, it tends to move the light up-down as it adjusts left-right as well as the top adjustment slightly moving the aim left-right when adjusting up-down cause that screw is top inside the high beam.
If these adjustment points were located in the middle of the horizontal & vertical points in the housing, they would adjust properly, but with them being located at opposite corners of the housing, you gotta "play" with em to get proper aim.........
sabot7726
04-28-2016 08:20 AM
Hydryman
02-23-2016 03:35 PM
mischman
09-15-2015 03:38 PM
