clear corner lens mod help
ive seen some xb1's with the clear corners. how do i do that? i did the mod on my chrysler with a flathead and some metal shears for the reflector, is the process the same?
there is a how to in the tech section that shows step by step how to pull the bumper and lights, but basically, you remove the headlights and bulbs, go into the hole for the blinker light with a screwdriver, and pry that reflector out in chunks. or if you are daring, heat the headlights and open then, and pull the reflector out and then put the headlights back together.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Opr8r
20
02-25-2004 11:29 PM
