Drill bit question for spoiler install
Old 11-24-2008 | 04:20 PM
dz302's Avatar
Default Drill bit question for spoiler install
I need some help. I purchased an OEM rear spoiler and I'm ready to install. According to the directions I need a 3mm and a 5mm drill bit. Problem is, I don't have one. I went to Lowes and Home Depot and shopped for them but all the drill bits are SAE.
Where can I get metric bits? I was thinking maybe Auto Zone or Advance?
Thanks.
Old 11-24-2008 | 04:28 PM
Sunny's Avatar
technically you don't need those. that is just to drill a pilot hole.
For the gigantic drill bits you actually need the 12 and 14 mm i suggest buying a step big. thats what i did. should be able to pick them up at a Harbor Freight store if you have one close.
Old 11-24-2008 | 04:36 PM
cherry-8's Avatar
You could always use an SAE equivalent.
If you go small, you might have to ream the holes out a bit. The larger sizes aren't all that large: .175 mm is just under 7 thousandths of an inch.
If you used a 3/16ths instead of a five, you'd have to ream the hole out about 9 thousandths of an inch.
7 / 64 = = .109375 = 2.778125 mm
8 / 64 = 1 / 8 = .125 = 3.175 mm
12 / 64 = 3 / 16 = .1875 = 4.7625 mm
13 / 64 = = .203125 = 5.159375 mm
Cheers,
MD
Old 11-24-2008 | 04:42 PM
dz302's Avatar
No Harbor Freights nearby. The instructions list the 3 and 5 but make no mention of any other drill bits.
Ok, I went and read all the way through the instructions and now I see that I will indeed need a 12 and 14mm bit. Seems as though I could use a small SAE bit for the pilot holes so I don't have to buy four new bits.
Do you think I could use an SAE equivalent size for the 12 and 14 bits? If so, which size?
Thanks.
Old 11-24-2008 | 05:07 PM
Box_Rod's Avatar
Just pick up a step bit like a "unibit". Sears sells them as well as Home Depot and Lowes. That is what I use to mount up the OEM spoilers in my shop.
Old 11-24-2008 | 08:31 PM
dz302's Avatar
Ok, I looked them up online. The one I see says ideal for cutting through thin material such as brass, ss, etc. Would that work? I've never seen these bits before, are they easy to use?
What size do you use in your shop?
Old 11-25-2008 | 02:50 AM
bbszero's Avatar
I used the SAE equivelants, I believe they ran a tad small, then i used a reamer to bring the hole to size and it worked great.
Old 11-25-2008 | 03:18 AM
Metro273's Avatar
The unibit is what I used, worked like a charm. Just make sure to work ssslllllllooooowly!
Old 11-25-2008 | 12:39 PM
Sunny's Avatar
[quote="dz302"]
Yup. Thats the one. They are super easy to use....however, i was scared out of my mind when i drilled with the because of the size hahaha.
It is simple, just go slow. You will feel when it goes up to the next step on the bit.
I can't stress this enough: MEASURE MEASURE MEASURE AND MEASURE AGAIN!!!!
the templates that came with mine were slightly off when i taped them up.
The hole markers on the template were correct, but the distance from template to template was off. measure the holes on your spoiler, and align the templates to that.
and then measure it again.
Old 11-25-2008 | 06:06 PM
dz302's Avatar
Ok, thanks for all the tips. I'm off to install the spoiler!
Old 11-25-2008 | 07:22 PM
cherry-8's Avatar
Nice metric equivalent table here:
http://www.accuratescrew.com/info/MetricSizes.htm#SAE
Cheers,
MD
Old 11-30-2008 | 11:06 PM
TypeX's Avatar
I just installed mine today
everything was great UNTIL i was done
and the doorlocks/brake lights didnt work
Possible i snipped a wire during drilling?
Anyone ever hear of that before?
I changed the fuses and all is working now but the only harness in there is the rear high brake light
THoughts input?
as for the OP
on the back of drill bits they convert them for you
Old 12-01-2008 | 06:28 AM
RideOrDie's Avatar
double side tape works great and isnt permanent...
make sure you get the heavy duty stuff. my $0,02.
MinusPrevious
15
06-13-2015 12:40 PM
TotalChaos
13
02-04-2015 11:24 PM
torranosaurus
01-28-2015 05:53 AM
kdepew
01-05-2015 01:42 AM
ScionDP
12-03-2014 03:05 AM
