Ebay / Halo projector headlight question - updated comment
#42
Wasn't hard at all. The whole process took about 15 minutes but the halos aren't hooked up yet. I only used a phillips screwdriver, a small flat screwdriver, and a 10mm socket. Remove the grill. Then pop the center plastic thing from the center of the front cover and remove the bolts from the front cover on the edge of the tire well. Then pull down and slightly out on the edge of the front cover where the bolts were to lean the front cover forward. Then there are just the 4 screws for the lights. For the basics it's just a matter of unplugging the headlight and taking the turn signal socket out of the assembly. Replug and reinstall the socket in the new light and reverse the disassembly of the front end and you are done. I didn't hook up the halos. I'll have to do that later. I'm going to hook mine up to a separate switch in the car instead of the park/turn lamps because I want to control when they are on.
_________________
Box Brigade
so do you have to take the front bumper completely off like on the last post or no?
_________________
Box Brigade
carid
01-08-2015 11:33 AM
jaspercanda
12-28-2014 10:09 AM
