firesports grill info / JDM Zenki headlight info needed
Dose anyone know if you can still get one. I know for a time that JDMPalace could get them, but the website is down so im guessing they went under. Any ideas. also anyone know where I can order the wiring harness for the city lights on the JDM Zenki headlights or any other spare parts for them.
Join this site (its free) and you can find all the part #'s, most of the stuff is also available here from any Toyota dealer. The bB Zenki heads are not DOT compliant, but you can retrofit them to work with the JDM bulbs and sockets by following this diy http://www.clubxb.com/forums/f19/usd...hts-35906.html
or like I did use the city lights as DRL's wired separately and modify a 7443 socket to give you turn signals and parking lights in the corner. you can get a 7443 socket w/wires from autolumination.
Toyota DIY pars reference
Autolumination
For retrofitting 7443 sockets
S/B three wires coming out of the back of the 7443 socket, one green and 2 other colors.
green s/b ground so put a bulb in the socket and touch the green to ground and 1 of the other 2 left to positive on battery if it lights the smaller filament that's the one for parking lights if larger filament lights then its the wire for turn signals.
put your findings on paper then follow the list below.
7443 sockets
1) _____ = turn signal
2)green = ground
3) _____ = parking lights
On the xB's turn signal/parking light wiring plugs this is the set up
Passenger side
1) green w/yellow stripe = turn signal
2) white W/black stripe = ground
3) green w/orange stripe = parking lights
Drivers side
1) green w/black stripe = turn signal
2) white w/black stripe = ground
3) green w/no stripe parking lights
need to remove all the little fins on two sides trim the corners and remove one of the large tabs
remove gasket
before trimming
trim all the 4 small fins on both sides
trim off one large tab (not the tab next to small fins)
trim corners/edge to fit in hole (bottom right corner trimmed in this shot to show diff)
Autolumination
7443 sockets
2)green = ground
Passenger side
Drivers side
remove gasket
before trimming
Thanks, most of that stuff I know about and I have the 7443 socket w/wires ready to go. i just did not know that a dealership would be abale to get parts for the JDM heads, because alot of the parts are not the same. the parts im really looking for is the wire bracket that holds the main bulb in place, and the wire harness for the bulb thats just below and to the left or right of the main. the guy i got them from Japan jiped me and im stuck right now with one that is ready to go and one that i need parts for.
I think the bulb retainer wire is the same as stock heads, the little 194 bulb socket is available here. When I get home I'll post part #s
You cab also get OE connectors and repair wires for all the sockets, let me know exactly what your missing
sadly the bulb retainer wire is not the same as the USDM ones. and Im missing the little bulbs as well as the connecters for them. btw thanks for all your help.
The city light socket (small 194 bulb in housing)
part # 90075-60001 need 2
connector for city light part # 90980-11162 need 2
repair wires (metal pins w/wires) part # 82998-12440 need 4
I will try to find out about the wire that hold the bulb in
make sure the lock is open when you insert the wires, they only fit in one way. Lock them in and you have OE connectors w/wires
