Fog light install and relay HELP?
Old 07-16-2007, 03:29 AM
NastysXB's Avatar
Default Fog light install and relay HELP?
got a set of fog lights off ebay. there nice and all but i no it didnt come with the relay i need. ive heard i can get it from sparkstoyota.com but where does it go? from the switch to the other wire plug thats under my dash? any help would be great.
NastysXB is offline
Old 07-18-2007, 06:57 PM
NastysXB's Avatar
no one has OEM foglights??
NastysXB is offline
Old 07-21-2007, 05:05 AM
05_JDM_bB's Avatar
Bump, I'd like to know. Are these foglights that you got the OEM knockoffs for around 70 bucks or something? If so, let me know how they work once you get them going.
05_JDM_bB is offline
Old 07-21-2007, 04:31 PM
scyon's Avatar
hope this helps And I have a relay 12.00 Shipped.. Let me know.
http://www.trdsparks.com/install/08590-52820inst.pdf
scyon is offline
Old 08-06-2007, 09:03 PM
crxlurp's Avatar
If you still need to get rid of your relay, i will take it off your hands for $12 PM me. not to steal it from NastysXB though
crxlurp is offline
Old 08-07-2007, 06:10 PM
NastysXB's Avatar
yea i tried to pm him but he never got back to me?
NastysXB is offline
Old 08-07-2007, 09:01 PM
scyon's Avatar
sorry guys I have been out of town taking care of some business. I have two of these so just pm me and and I can tell you whee to send the money
Thanks Eddie
scyon is offline
Old 08-09-2007, 03:49 PM
Team XcelsiA
Team Sushi
06scioxb's Avatar
the relay goes behind the fuse box it is the farthest to the left i will try to get you the pix
06scioxb is offline
Old 08-10-2007, 03:59 PM
BoiseAuctioneer's Avatar
Is the relay really needed? I will ONLY use my fogs at certain times so would hooking it up to a switch with constant power be such a bad idea?
BoiseAuctioneer is offline
Old 08-15-2007, 07:01 PM
NastysXB's Avatar
Okay i got the relay from scyon thanks!!
New problem= switch that came with fog lights does not plug into the conn. thats in my dash??? what do i do? PICS...
Switch has 4 prongs and wire in dash only has 2... and it doesnt fit? help me plezzzz
NastysXB is offline
Old 08-15-2007, 07:04 PM
dz302's Avatar
No, it is not needed.
dz302 is offline
Old 08-15-2007, 07:07 PM
I was told it could over heat the switch and cause a possible flame
Old 08-15-2007, 07:13 PM
crxlurp's Avatar
ok i got my relay also, but on my 06 i cant find where i put the relay. are the 06 different? can someone post a pic for me?
thanks
crxlurp is offline
Old 08-15-2007, 07:15 PM
crxlurp's Avatar
do you have a picture of the front of the switch? does it light up?
crxlurp is offline
Old 08-15-2007, 07:28 PM
dz302's Avatar
The only thing a relay does is to supply power to your fog lights when "only" your headlights are on, and they then must be on low beam. That way, you can't run your fogs alone, or at the same time as your high beams.
Just run your power wire (with an inline fuse holder of the proper amperage) directly to switched power. Then you can run your fogs anytime you wish, and the fuse will protect you from overload.
dz302 is offline
Old 08-15-2007, 07:49 PM
crxlurp's Avatar
well i got pm'ed with the answer to your question so here is what he said:
"had this problem too with the ebay one. the switch they gave is the wrong one. i just bought a switch from autozone and just customed it on one of the blanks. it is easy to do. power to power ground to ground. easy."
you could get this one to work, but you will need to find out which pin is what. i would just say trial and error on it.
crxlurp is offline
Old 08-15-2007, 07:54 PM
NastysXB's Avatar
so what wires are power and whats ground on the wires coming outa my dash? or do i just hook each wire to a side of the switch? because theres only 2 wires..
NastysXB is offline
Old 08-15-2007, 07:56 PM
crxlurp's Avatar
the black/white is ground and the green is power
crxlurp is offline
Old 08-15-2007, 08:11 PM
crxlurp's Avatar
can you send me a pic of where you put your relay?
crxlurp is offline
Old 08-16-2007, 06:47 AM
scyon's Avatar
Fig 5. pages 4 and 5 of 7 is where you can find where the relay goes.. (c5 and c6)
Hope that helps
scyon is offline
Quick Reply: Fog light install and relay HELP?
