front side marker rewire question
i tapped the front sidemarkers into the parking lights and everything works correctly. front sidemarker signals like normal. while parking lights are on they'll turn on, then they'll blink alternate to the front and rear signals. only thing is, when the hazard lights are on, the rear sidemarker and license plate bulbs will flash also, but its a very dim flash, not a real one. looks like its getting a small current or something. also when you lock/unlock car with remote, rear sidemarker and license plate bulbs will flash with the same dimness as when the hazards are on. anyone else have this problem and how could i fix this?
^^i found the problem. my wiring was all done correctly. it was just the led's in my license plate that was causing the flashing. swapped those out now everythings working like it should.
umnitza
12-01-2014 06:26 PM
