Headlight Electrical Problem?
SO I got this problem... originally I had HIDs running in projectors in my 05 xB for quite a while, near a year maybe, but then I noticed my left light would flicker on for one second when I turned them on and then it would just go out. The left one was fine, and when I plugged my left headlight bulb into the right ballast, it lit up fine, so not a bulb problem. Next, I removed both HID setups and went back to the old halogen bulb setup, and now is where I got confused....
Now my right bulb lights up normally, and my left bulb barely lights up (if at all?), but it still lights up. It is very dim, like it isnt getting enough power? I double checked all the connections and everything. Also, my maint req. light has been on ever since about the same time this happened, but I believe that is because it wasnt reset at my last oil change.
So how am I not getting enough juice to my left headlight? could it be a simple fuse problem? Pictures:
Recheck the grounds. Power is getting there as the light works. Problems like this are more likely on the ground side. Look for loose or corroded grounds at the core support. Worth a shot anyway.
I had the same problem ,but i was running h.i.d.'s in the headlight assembly and they just quit working ,so i rip all the h.i.d. stuff out (audi ballast w.philips bulbs) and put o.e bulbs back in and had the left headlight bearly lighting up and started back tracking the ground ( I was sure I roasted the ground) well to my suprise everthing was fine .......
I just simply blew a fuse!!!!!!!!!!!
the retarded thing is I spent an hour check the ground
I assume toyota did the math ,,but the ground for the headlights seems really small???? anyway CHECK YER FUSE(s)
I dont mean to thread jack ,,,,but when i wired up my HID's when the ballast would touch the frame (or any ground for that matter) it would spark ,and the AUDI ballast I have are simple as hell ,2wires red & black
anyone with any idea on that ,,inadiquit ground ,,maybe??
I'm not into auto mechanics much but I believe the fuse box is under the hood on the right side. It looks like a small plastic box, the top just sort of pops off and on via some plastic grips on the sides.
S7ephavs
03-22-2015 12:09 PM
missing_image
02-07-2015 07:18 PM
