Oznium Piranha Bar Third Brake Light
Old 05-27-2008 | 07:42 PM
TheDivineComedy's Avatar
^^^thank you
Old 05-27-2008 | 08:48 PM
Robbie's Avatar
yea Ill try and write one up tonight
Old 05-27-2008 | 08:52 PM
Big_Bird's Avatar
Sweet thanks man
Old 05-27-2008 | 09:13 PM
aalbertson3's Avatar
Nice and bright! Oznium FTW.........
Old 05-28-2008 | 06:07 AM
Robbie's Avatar
sorry I wasnt able to post the how to I will post in the next couple of days.............I promise
Old 05-28-2008 | 10:55 AM
Skuff_Box's Avatar
watching
Old 05-28-2008 | 12:21 PM
Keith's Avatar
watching
Old 05-28-2008 | 12:28 PM
Eltaco's Avatar
Very sick, I was thinking something similar to this at the top of my hatch frame in my tC. I wonder if 4th brake-lights are legal.
Old 05-29-2008 | 02:45 AM
Robbie's Avatar
Ok so this will be my first how-to write up so go easy on me
1) First thing I did was take the 3rd brake light apart. There are 2 bolts. You just remove them and it pops out. I then took the light bulb out and kept the connector for the third brake light wried. I DID NOT CUT THE FACTORY WIRES. I had a connector for a 194 from oznium that you get when you buy a dome light from them. I simply wired that to the Paraniha light and pluged it in.
2) I then bought some Stanley Mending plates that worked perfect. There are 2 predrilled holes and I screwed the provided holder to one hole and screwed in the other part to the metal above the window
3) I then drilled a piolt whole above the window(Be careful not to hit the glass) and I dremled down some screws so that they were really short and I mounted the brackets to the window.
Here is a view from the inside the problem Im having is making it look nice from the inside. So any ideas are welcome
I had fun doing this and I really like it it looks sweet and is very bright.
Old 05-29-2008 | 12:08 PM
WhoKilledTheJAMs's Avatar
Maybe you could carve a mockup housing out of foam, and make it out of fiberglass, or have someone vacuum form one?
Old 05-29-2008 | 08:29 PM
burstaneurysm's Avatar
Yea, a glassed housing would make this very, very pro.
Old 05-30-2008 | 01:43 AM
Thats nice!
What about using a pipe? Just big enough, with end caps cut in half?
Old 05-30-2008 | 05:47 PM
Robbie's Avatar
Thats a good idea!!!!!!!!!
Old 05-30-2008 | 07:07 PM
Good idea! Maybe you could use a black PVC pipe...... Would be really easy to cut.
Old 05-30-2008 | 09:21 PM
how i thought of that i couldnt tell you. wed worked 12 hrs, 5 hrs sleep, got up at 7 and put headlights/taillights on car and was at work at 3 to midnight and back today and 930. TGIF!!!!
Old 06-03-2008 | 04:15 AM
plus using the pipe, you might be able to use the stock location and not have to drill extra holes.
Old 06-04-2008 | 01:28 AM
just bought this light bar and a dome light. Prolly do it this weekend. Was shipped out couple hrs after I ordered it.
Old 06-04-2008 | 01:32 AM
Robbie's Avatar
sweet let me know how you mount it
Old 06-06-2008 | 09:04 PM
robbie - did you have to add some wire to get it hooked up. Looking at yours above it looks like you did.
Also just a thought, without measuring, could put 2 up there. Have it all the way across, though there would be a gap in the center.
Old 06-06-2008 | 10:55 PM
Robbie's Avatar
yes i added about 18inches of wire. I thought about 2 aswell but i didnt want the gap
