Oznium Piranha Bar Third Brake Light
Old 06-25-2008 | 05:38 AM
  #81
snowromance's Avatar
Originally Posted by Iateacricket
I've had no issues with mine, though I have a 2005 with the TYC tails. No cruise control.
for anyone wondering, this is because the TYC tails have the standard regular filament light bulbs. Not LED.
Old 06-25-2008 | 06:47 AM
  #82
TheDivineComedy's Avatar
try it again... turn on the cruise control (while parked of course, just push the button on) and the 3rd brakelight will come on dim. That's what was happening to me while i was troubleshooting. The first sentence in this paragraph, describing the results with the resistor in, sounds like normal operation to me. that is what you want to happen.
Just tried it. Put the light bar back in. Started the car. Checked to see if anything was dim. None and no warning dash lights. Pressed brakes and all worked correctly. Turned the cruise on and nothing came on dim and no warning lights.
Old 06-26-2008 | 12:20 AM
  #83
so it's fixed. right?
Old 06-26-2008 | 12:52 AM
  #84
No. The cruise is not working still.
Old 06-26-2008 | 11:38 PM
  #85
Should of been more clear. I took it for a little drive to see if it would work and hte cruise never came on. I'll put a resistor on the tails to see if that does it this weekend.
Old 06-27-2008 | 12:10 AM
  #86
well you can check out my cheezy wiring diagram i made in paint... that is EXACTLY how my sonars are wired. and yes i have an LED 3rd brakelight. Yes I have cruise control as well. and yes everything works exactly as it's supposed to.
Old 06-27-2008 | 12:18 AM
  #87
it needs a resistor on each side?
Old 06-27-2008 | 05:10 AM
  #88
that's just how i did it, everything works fine. i have one of those radio shack resistors spliced in parallel across each brake light circuit of both harnesses. no extra load resistance in the 3rd brake light though. everything works perfect.
Old 06-30-2008 | 02:14 AM
  #89
I havent had a chance to get it done yet. I do have the resistors though. Is there any problem with them heating up anything and melting stuff? the tails or anything else back there.
Old 06-30-2008 | 03:06 AM
  #90
they do heat up, but they will be wired through your brake lighting circuit so they will not be on all the time. i cant say for sure that you will not have a problem with heat, but i have not had any problems with them.
Old 07-23-2008 | 06:11 PM
  #91
Finally tried to put resistors in this past weekend. Didnt work. Giving up. Tired of fighting with it.
Old 07-25-2008 | 01:14 AM
  #92
sorry you are having trouble figuring it out :-(
xBSciontist
06-18-2019 04:06 PM
mischman
01-14-2015 07:07 PM
VCUBoy714
Scion tC 1G ICE & Interior
01-05-2015 09:46 PM
bruceb25
11-23-2014 05:52 AM
crystaljukebox_com
12-16-2003 09:34 PM
