Rear Door Handle Reinforcement
Old 12-24-2006 | 06:18 PM
UBOW's Avatar
Originally Posted by vintage42
Originally Posted by UBOW
... My only complaint is the cheap rear door lift handle. It is flimsy and has broken on me. I have repaired, made it better and stronger, then reinstalled it. Every box owner should take theirs off and perform this simple modification...
How can we do this? Is is described in some other thread or DIY?
I didn't take photos of what I did, sorry. but I can descibe it simply enough.
1 - Remove the inside panel from the rear door by carefully prying the pop-fasteners off.
2 - Remove the two harnesses for the license plaste lights at the connectors.
3 - Remove the two 10mm nuts from the studs that hold the lift gate handle.
4 - Block the door so it doesn't close with a rag over the door sill catch and lower the door.
5 - The handle should slide up and off the rear door, not out and away.
You will now see the two studs that the 10mm nuts thrreaded onto. They are pressed into two plastic stand-offs that is a part of the handle. These stand-offs have very small and inadequate gussets.
6 - What you do now is take two plastic caps from soda bottles adn remove the inner seal.
7 - I used a 7/16" drill bit and made a hole in the cap mostly on the side and a little on the top.
8 - Test fit over one of the stand-offs and trim to fit. The open side of the cap will rest flush on the backside of the handle.
9. Complete both caps before proceeding.
10 - With a strong, reliable 2-part epoxy, fill each cap and set them in place. Add more epoxy to form a fillet around the outside of the cap. You do not need a lot of epoxy as epoxy in itself is not a structural material necessarily, depending on the kind you use.
11 - Allow the handle to cure and dry for 24 hours! This is essential. There is no shortcut here, no way to speed it up - not even oven-curing.
To reinstall, the handle slides back on to catch the two clips. Put the two nuts back on but do not over-torque. My rule-of-thumb is snug plus 1/8th to 1/4 turn for plastic parts. Reattach the harness (you can't get them wrong), put the rear panel back on and you are finished.
Old 12-25-2006 | 03:14 AM
UBOW's Avatar
From this thread: https://www.scionlife.com/forums/vie...159238#2159238
Do it before. All owners should. This should be a "must-do" preventative maintenance....
OK. It looks like the write up has moved, but I copied it and have a question. You say:
It may be evident after we get into it, but what does drilling a soft drink cap "mostly on the side and a little on the top" mean?
The stand-off comes off the inside pf the handle at an angle so you can't make a hole straight down through the bottle cap. It must be an eliptical hole penetrating the corner of the cap where the top and the ribbed side of the bottle cap meet. When you take the handle off it will make sense to you. Perhaps tomorrow I will find a way to take a couple photos and bury them in someone's website.
HTH
Old 02-27-2007 | 04:27 PM
jsa3mm's Avatar
Pictures would help tremendously.
Old 03-31-2007 | 04:26 AM
06ShadowBoX's Avatar
damn this article is useless without PIX!!!
Old 03-31-2007 | 05:09 AM
Metro273's Avatar
^^^ X2...
Old 03-31-2007 | 05:26 PM
UBOW's Avatar
Hey, I've been busy, gimme a break! When I get a couple of hours, I will disassemble my rear door and take pix. Okay? Maybe in a week or two, now that the weather is getting better.
Old 04-04-2007 | 08:13 AM
GreenLantern's Avatar
watching......want to do this...my whole piece back there is loose and rattles with the bass kickin'
Old 05-07-2007 | 11:09 PM
g0nk's Avatar
anyone able to do this and take pics? it would be nice..
my new '06 is starting to show signs on the left side of the handle that it is starting to get loose. I plan on trying this possibly in a couple days, if no pics get posted, i'll try my best to take some and add to this article.
Old 08-17-2007 | 10:00 PM
any updates on this?
Old 10-05-2007 | 05:03 PM
bump for pix!
Old 06-03-2008 | 10:36 PM
teamkasnomas's Avatar
Default thank you...
for keeping this thread alive. hatch broke again. pursuing bottle cap solution.
Old 07-26-2008 | 12:52 AM
kirksucks611's Avatar
bump
Old 08-25-2008 | 09:54 PM
i got the chrome one. installed it in what seemed like 10 minutes.
Old 08-26-2008 | 02:21 AM
Guest
Guest
Posts: n/a
Are you all talking about the rear hatch? Or the back door on the side of the box?
Old 08-26-2008 | 04:04 PM
the liftgate handle thing .. the thing that is chrome. i replaced my broken one with a chrome one from scionpro.com
Old 08-28-2010 | 11:30 PM
BiteXb's Avatar
Is the bottle cap thing needed if you are installing the ScionPro chrome rear handle?
Old 08-30-2010 | 12:35 AM
BiteXb's Avatar
I installed my scionpro chrome rear handle today. I did not do that bottlecap thing and really don't think it is needed. I am not sure I really understand it anyway. The install took me about 90 minutes going really slow.
Also, I now have my flawless old hatch handle, which is camo, so if anyone needs a new one. Let me know and shoot me an offer. It is clean and scratch free. Really nice shape. Like new.
Old 02-06-2012 | 06:40 PM
UBOW's Avatar
There have been many people who have done the fix as I did on mine 3 1/5 years ago. It has worked "okay". I have decided in the next few months I want to removed the hatch handle and license plate altogether, fill the hatch completely and cut out a new license plate hole into the bottom left. Then insert a flush-mount glass cover over the license plate that will be illuminated all around from inside.
Old 03-27-2012 | 04:52 PM
rikshaw's Avatar
There is an online petition and a Facebook page to get Scion to fix these.
http://www.change.org/petitions/scio...sumers-at-risk
http://www.facebook.com/#!/pages/Sci...95767133769843
Old 05-25-2013 | 09:31 PM
George's Avatar
Scion will replacing handles on all XB1s regardless of warranty status until 13 March 2014:
https://www.scionlife.com/forums/sho...=1#post4110976
dom96
Scion tC 1G Aero & Exterior
07-07-2021 02:48 PM
mischadoll
03-09-2015 06:48 AM
idriveanxa
03-08-2015 01:03 PM
toyotaisme
01-10-2015 11:24 PM
wizzlexB
12-27-2014 05:06 AM
