2006 xB Scheduled Maintenance - "Tighten drive shaft bo
Old 07-18-2009 | 09:34 PM
Sactokit's Avatar
Default 2006 xB Scheduled Maintenance - "Tighten drive shaft bo
Can someone point me to the Service Manual reference or other wise locate the "Drive Shaft Bolt" and torque?
Thanks
Old 07-18-2009 | 10:47 PM
GRNDHOG's Avatar
subscribing to this thread as I'm interested, too.
Old 09-05-2009 | 08:19 PM
Sactokit's Avatar
Default XB - "Drive shaft bolt" location?
Where is the xB - "Drive shaft bolt" mentioned in the maintenance lists?
Old 09-05-2009 | 09:14 PM
sdsnybny's Avatar
All the Toyota shop manuals can de downloaded for free here along with some other useful info http://scionlife.org/Scion_Docs/
here is a good microfiche for part #'S Toyota DIY pars reference
Old 09-08-2009 | 05:40 PM
cherry-8's Avatar
I don't know if this will help, but here goes.
There's a nut at the end of the drive shaft. It has a tab and is torqued to 158 ft. lbs.
You attach your wheel to four bolts called hub bolts press fit into the back of the hub. They are torqued in with the wheel nut to 76 ft. lbs.
There doesn't seem to be such a thing as a "drive shaft bolt." Only an "axle nut" or "hub nut" and the "hub bolts.
The parts are described in section 30 of the shop manual: Drive Shaft.
Here's a quote from Toyota Nation from 06 about the same maintenance item in the Corolla manual:
"Quote:
Originally Posted by plrsgator
After a search via all forums I see that many Corolla/Matrix owners are as perplexed as me. Guess i'm not the only one 'clueless'... Sounds like a job for the MYTHBUSTERS.... Just kidding. Gonna call "Mother Toyota", wait on hold 20 minutes, and just maybe... I get to talk to a technical versed individual who won't tell me to visit the local dealer... Regardless, I'll share whatever "Mother Toyota" reveals about this elusive (invisible?) bolt.
Mother Toyota was no help. Can't talk to a "mechanically educated person"... However, this time I got a male "service advisor" (at my selling dealer) who actually would listen (owned an 05 Corolla himself). He conferred with the technicians who ackowledge the bolt's existance but said they never found one loose and therefore never check it during routine maintenance. He offered to have mine checked (during the $24.95 20K service) and would even have their technician show it to me.. Granted I did mention that I was in contact with Corp. (Mother Toyota) and that Corp. was interested/concerned with the solution to my question/situation..."
Others suspect it is simply a Toyota/Scion major typo.
Cheers,
MD
Old 09-08-2009 | 05:52 PM
jct's Avatar
jct
its for rwd apps...
Old 09-08-2009 | 11:27 PM
cherry-8's Avatar
Originally Posted by jct
its for rwd apps...
So I guess they just lifted the maintenance info from the Tundra manual?
Cheers,
MD
Old 09-08-2009 | 11:29 PM
jct's Avatar
jct
its just cheaper for 'em do to so it also works on 4x4's and awd's systems
Old 09-09-2009 | 02:22 AM
Sciond's Avatar
been discussed many times OLD OLD OLD...search is your firend
Old 09-09-2009 | 02:27 AM
Sciond's Avatar
here is an old thread
https://www.scionlife.com/forums/sho...ive+Shaft+Bolt
DaBlackBox
134
04-10-2022 02:04 PM
Kiwibox
12-15-2014 09:46 PM
TheRedBox
10-08-2003 04:25 PM
Quick Reply: 2006 xB Scheduled Maintenance - "Tighten drive shaft bo
