A/C STOPED BLOWING COLD AIR Help!!!!
ok so my a/c stopped blowing cold air this weekend any ideas I checked most all the fuses and nothing. Help please its going to be real hot this week.
a/c
did ur air just stop blowing cold as asoon as u turn it on or is it after u car sits for like ten minutes and then u try to turn it on and its only hot... if its the second one it happened to my 05 box too and i took it to the dealer and they had no f-in clue what was wrong with it... first time they said it just over heated and it should be fine.. three times later with the same problem they finally swapped out my blower and its been fine since for the most part... i noticed that it happens when the car is idle for about 2o mins with the air off and then when u turn it on ur f-ed becasue then ut doesnt work.. just thought id throw my 2 cents in
mike
mike
i would take it in and see if it needs to be recharged. mine throws out moderately cold air on moderately warm days. it is a small system so you can ask for too much, most likely it just needs the freon changed out.
Hey EZ, if it just started, it's possible that while you were driving, some vehicle in front of you, kicked a rock thru your AC condensor, since it's so exposed to the elements.
As far as people saying you need to just recharge it, NOPE! If it needs a recharge, it's cause there is some sort of leak in the AC system.
Let us know what the dealership finds...
OK so I took it in today to have them check it out they told me my compressor clutch went out and is stuck on so thats what blew the condencer and my woranty is up so its all on me. a 2004 with 47,000 miles sigh.
hampton1100
05-28-2015 08:32 AM
carid
03-30-2015 08:08 AM
