Caliper Paint
I looked into the Dupli-color caliper paint and found that it was $15 versus $5 for the Engine VHT. They both have the same heat rating and the caliper paint is brush on. I'd rather save $10, mask it and get a better smoother looking job, and even though it is mostly B.S., the thinner paint will actually insulate a tiny bit less allowing the calipers theoretically anyways to cool better. Also, you actually get better coverage from the spray paint as well.
If you check my profile, you'll see my 2.0 pics with the painted calipers and drums. (The Ford red is really a nice color for calipers)
johncal
johncal
It's a preference thing. I don't like spraying and I would feel like I had to mask of the rest of the car to avoid overspray. The brush-on is a ceramic based paint and will dry smooth without brush strokes if you're patient and careful and do a few coats. Maybe not quite as good but close enough for me.
I went with yellow to match my GoldLine springs. If you don't want to add another color, I'd just do black. Be sure to get the hat and outer edge of the rotor and the brake drums too. If you black out the wheel wells it will just look like it is stock black and not an accent color. The caliper in it's OEM form is a nasty bluish grayish color needs something done to it for sure.
rvascion
11-12-2020 03:23 AM
gqdabien
07-22-2015 10:30 PM
