Dangerous??? - Pebble Hit Front Window, Left Exterior Crack
A pebble hit the front window of my xB & left a small crack about half a centimeter, or quarter of an inch. The window glass seems to be multi-layered; therefore, there is no air passing through or anything. The crack is only on the outside.
Is this dangerous? Do I have to get an immediate window glass replacement?
Please help! Thank you!
I had the same thing happen about 2 years ago. A rock hit my windshield and gave it a spider crack about that size. I just used a $10 windshield repair kit to prevent it from getting any bigger. It also helped to reduce the visibility of the crack, and made it less noticeable. So far, so good.
If you have trouble fixing it yourself, places like Safelite Auto Glass can seal it for less than $40. It will prevent the crack from spreading. I have had this done a number of times and the cracks haven't spread even in cold Montana winters with the defroster running.
Thanks.
Thanks.
The same thing happened to me about 2 weeks ago, with a small pebble aswell!
Sure enough, every cold and warm day that went by, the crack moved about 1 inch everyday. Eventually it stopped, after another 8-10 inches! So ya, it's gonna get bigger...
Lol, my windshield is riddled with chips, not a single one ever expanded on me. I have had a chips since a little after owning the box, so some have been there almost 4 years. Still on my original windshield. If you look at my windshield it looks dirty, but it just has hundreds or chips, lol. I now have a crack in the windshield, but that is because I punched it, oops.
Your glass isnt multi-layered, its covered on both side by a thing layer of plastic/vinyl.
Check your insurance policy, as lots of writers are now offering glass replacement. Mine is free and unlimited.
Get a glass repair kit from your auto supply store. I used a low speed drill to clean my first chip prior to using the resin. If you aren't looking for the chip, you can't tell it's there. Cost me about $7 to fix it.
Originally Posted by OakToddler
What do you guys do if you window has what looks like an abrasion?
No crack but looks terrible and is distracting when you drive.
Is there something that can be used for abrasions?
BTW ... when i say cheap i say that based off the fact that when the xB was first introduced here to the states and later to the East it was $600 easy for front glass. Now its a 1/3rd that price at Safelite.
Web-Only Price: $275.95
(includes labor, before tax)
View Detail
Your vehicle may require the installation of moldings and accessories at an additional cost of $29.95. Learn More
Front wiper blades installed for $22.98.
This quote includes a National Warranty that is good for as long as you own or lease your vehicle. The quoted price is good for the schedule options listed
No clear ones......
View Detail
No clear ones......
I would suggest calling your insurance company. Most of the time they will pay the cost to have it repaired. If not call safelite auto glass. It is better to have a profesional do the work. At most it will cost you about $40 and they should still offer a lifetime warranty on the repair ( I used to work for them).
Also safelite will come to were ever you are. So you can call and set up an appoitment to have them come to your work or home.
Just safer that way. Cause if you screw up the DIY kit it will cost you more in the long run.
JUst my $.02
JUst my $.02
ive had multiple dings in my original windshield that never got worst, especially in the changes in temp that philly has. winter from 0 degrees to 40 everyday, and summers hot and humid around 100. it took me hitting them with pliers to finally do enough damage to have it replaces.....
TheTripleC
01-04-2015 06:46 PM
