Fog Lamp switch wiring
Old 07-30-2015 | 06:58 PM
Rob54Monty's Avatar
Default Fog Lamp switch wiring
Adding Fog lights, wonder how/where to wire the switch, rest of it is already run factory style...
Thanks and sorry if im posting on wrong spot, seems im locked out of most areas.... not sure if i signed up right...
Wire seems to go into the harness about 1 foot from the switch (junk yard car), but not sure what it wires into as the switch did not come with wire or the plug that fits in the switch either...
Last edited by Rob54Monty; 07-31-2015 at 06:42 PM. Reason: figured it out how do i delete post?
Old 02-02-2023 | 01:47 AM
TheBu_TC_her09's Avatar
i wired my fog lights in the the parking lot wire in so when i turn my running lights on it activates the switch. just ran the wire down the left side on the dash by the hood release and found the appropriate wire to conenct (i believe it was the blue wire on my car). and then just quick spliced it in and then you have to run the positive red wire thru the firewall and connect it to the battery.
Old 02-02-2023 | 07:59 PM
2stroked's Avatar
No in-line fuse?
Old 02-02-2023 | 08:24 PM
MileHightC's Avatar
Super Moderator
SuperMod
Originally Posted by 2stroked
No in-line fuse?
I think this answers that question, "i wired my fog lights in the the parking lot..."
Why use the wiring that Scion already provides that also uses a relay when you can just run a random wire or two and, even better, it's a reply to a nearly 8 year old thread.
Old 02-03-2023 | 09:26 PM
DannoXYZ's Avatar
Moderator
Moderator
Yeah, I just used wiring that was pre-installed at factory.
3kuL
01-08-2016 10:22 PM
wzard999
Scion xA Aero & Exterior
03-01-2014 10:26 PM
BAMF4Life
Scion tC 1G Aero & Exterior
33
10-23-2009 10:54 PM
chubbykai
Scion tC 1G ICE & Interior
08-19-2007 04:50 AM
Mcfly315
12-21-2005 01:34 PM
