Fog Light switch wiring help
Hey, so I have been trying to find a way to wire in a dual led rocker switch instead of the standard fog light switch. I can't seem too find what the two wires on the OEM connector are and where they should be connected. The two wires are a black/white and a green/orange wire.
The rocker switch that I have is .
It's a 5 pin or post switch. Two grounds for LED, one for acc, one for 12v+, and the last is for illumination (dash lights).
I have a good idea that the green/orange wire is to the relay, but have no idea what the black/white wire is(maybe headlights?), nor do I know what wire to attach to the illumination.
Any help would be greatly appreciated!
Thanks!
Thanks!
Update:
found a link to the wiring diagram finally!
Still unsure if I can use the headlight wire as an illumination, or if i should try to tap into the ignition to illuminate the switch as sort of shown in the link below?
https://www.scionlife.com/forums/xb-...lights-130083/
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 01:34 AM
