Fog lights?
Fog lights?
Noob ?: Anyone have any reccomendations on fog lights for the xA Release 1.0? I would like to use them on my very stock xA (the holes are in the grill already), but am looking for opinions/examples from people that have them already. Thanks!
-Aaron-
P.S. Are their any headlight/taillight kits (HID or similar) for the xA?
-Aaron-
I got the factory kit from Spark's Scion (ask for Ken) for $218. The kit comes with the wire harness, relay and switch. It main harness is already there so it just plugs in.
However, I want my fogs to be independent of the headlights so I'm looking to get them wired differently.
HTH
HTH
Originally Posted by CivicEater
i have Hella Optilux 2500's.. a bit of a squeeze, but they're the best damn driving lights i've ever used.
do a search.. this has been covered
if you want to wire the fogs independantly, just tap into the hot supply line for the harness and power it off a different source.
oh, as far as "bit of a squeeze" you do have to trim some of the rubber inside the bumper area. not visible from the outside. the lights are maybe 1/8" too large to fit the holes, but i built aluminum "brackets" to hold them into place very securely.
i only have pictures of them installed.
Nice...
Thanks for the help everyone! I would like the foglights to be independant of the main's as well...any specifics/sites/guides you have on tapping the power for this? The cutting and mounting part is not the problem, but as for electrical, that's a whole other ballgame. Thanks!
-Aaron-
-Aaron-
find a good + source under the dash. i used a test light and found a wire that was hot with the ignition switch in the ON position, but not hot when ign = off.
then use that as your source. i can't really explain it any easier.. there are some blanks in the fuse panel that have this power source.
They should be here by Friday.
Thanks!
Thanks!
Control / Switch?
CivicEater: how do those lights work?
Is there a switch setting to turn on the "Angel Eye" part, then the main bulb separately?
Or does the Angel Eye turn on with the headlights - like a BMW's?
Thanks!
Trevor.
Thanks!
Trevor.
it's a 3 way rocker.. one for angel eye, one for the actual bulb.
Epitrochoid you may have to do some testing of your own.. remember, it's only 2 wires to power the fogs, a + and a ground. honestly, all that other wiring is a waste, unless you want to hook into the stock harness.
SkillFreeJake
Scion tC 2G Aero & Exterior
07-27-2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
01-20-2015 01:41 AM
carid
01-08-2015 11:33 AM
