How can i safely jack up the xB and use stands?
how do u jack it up? use the stock jack then a better one once it gets to a good height? used to do it with my echo lol, but because of that i got in a rush and the stock scissor folded and the front passenger fell on the disc brake 0_0
i just use the stock jack for the first side. and if i need both sides up ( driver and passenger) i get a jackstand on the first side then use the scissor jack on the other side. i had a decent jack but it broke. and only way i'd buy any other jack was if it had 2 inch clearance which none do.
i use a 1987 toyota supra jack. it worked for my 3450 pound supra so it works for my 2435 pound scion. i love scissor jacks. cuz they go low. unlike all others.
You could also cut a 2X8 at a little angle and drive up on those first to give a little more clearance.
I made them use the jacks and not put it on the lift when I got my tires swapped today. They had trouble getting it on the last time and with my new lip and skirts I was like Even then it was close...
yea i cant even jack up my car anymore. scion jack broke (im too lazy to get it fixed) and my floor jack cant get under it anymore. i cant go up the drive on lifts.
only thing i can do, is find a shop that specializes in lowered vehicles, and have them use the 4 point arm lifting jack
scott
scott
ummmm most lifts (drive on type) come with lengthened ramps so as to fit lowered vehicles. just about every place around here has em. i guess nebraska is in the dark ages.
Music City Scions
I really can't believe this is actually at topic of discussion. I will NEVER use the jack that came with the xB. It will damage the paint on that seam and prolly bend it. The only safe way to jack it up is on that frame rail.
My floorjack has a large enough dish in it for a nice 4 inch piece of 2x4 to fit into so there is no metal to metal contact. And it goes low enough to clear the skirts. If not just place scrap pieces of 2x4's in front of the tires and drive up them to give added clearance for the jack. NO BIGGIE! Honest.
Those rails are strong enough to raise the whole side of the xB in the middle. I do it all the time and have yet to add one dent or scratch to them.
I am going to continue to jack the car up on the frame rails and not the body seam. I don't feel like opening myself up to scratches and future rust. I use a low profile floor jack with a 4" rubber pat on it. My jack stands areabout 1.5" wide and I use plywood on top of them. I have had no issues thusfar. No scratches, no dents, very sturdy feel.
Music City Scions
yea i think Max has a good way of doing it here and i agree with him. hes a smart fellow.
by chance though, where did you get your jack and how much did it cost? im pretty low and i have lots of problems getting the jack under there, let alone a rubber pad inbetween.
thanks
scott
thanks
scott
Music City Scions
thanks
scott
thanks
scott
thanks
scott
thanks
scott
I hate to admit it, but I got my jack and stands at Pep Boys. I did get the best one they had. I was in a bind when I bought it, and couldn't find a comparable one around. It's a Big Red Jack, made by Torin. It does a real good job, and it's reasonably light, at 42#. It's a dual stage (meaning it raises quickly to hit the car, then slower to do the jacking) and it's very low profile. This is just like it, except mine's red:
http://www2.northerntool.com/product-1/200313357.htm
The jack stands are each 3 ton and it came with two. I believe I paid around $120 for the set.
While it's clearance is 3.6" it does not reach super deep under the car, and since it's wedge shaped, the sides start to hit right as I get to where I want to be (on the frame rail)
I am on Hotchkis springs. Anyone with a 2" drop or more would have a tough time using this jack to hit the frame rails without driving onto blocks.
The stands are super light and look nice. They work well. They're aluminum. There's not much else to say about a jack stand. They seem quite sturdy.
Overall, I am very pleased with the jack and stands.
cool, i guess this is another reason i should bag my box instead of dropping on springs :D
i could just pump the bags up then jack right? I'm assuming people with bag setups do this?
Sgtfluffy16
Regional - Northeast
07-28-2021 10:32 PM
