How is the OEM rear spoiler attached??
What is the probabiliy of my dealer messing up the installation of my rear spoiler? Obviously their will be two holes drilled with a template, but i noticed that the spoiler has caps on either end on the top. That tells me that the spoiler has bolts or screws that tap into something from the outside correct? I was checking out my pop's rear spoiler in his new 4runner and noticed that its attached from the inside, not from the outside. anyone who has done this procces before please reply!
don't know if it helps... but i just installed my carbon fiber OEM rear spoiler. It came with 2 x 10mm bolts... i had to drill two holes...small enough to screw the bolts into..and used some 3M industrial strength double sided tape for extra security. It's very sturdy.
the dealer shouldn't have any problem installing it...it's just matter of price.
Originally Posted by UnFocused
COOL, thanks! So do the bolts tap into the metal, or is their a nut on the underside? I could not tell at my dealership...
i'm not sure how others do it... but there are several ways of installing the bolt. One is by utilizing a rivet gun with threaded-inserts...which one of my buddy have mentioned that it does not hold sturdy as it should. so, i'm opted to drill the hole and just screw the provided 10mm bolt into the metal. It's pretty tight .
sIcKsCiOnS
Re: How is the OEM rear spoiler attached??
Thanks for the replies....Im still confused though- does the bolt go through and attach with a nut, Or is it tapped in the metal.
My dealer just started selling scions, but im assuming they have done other spoiler installs on other toyotas- do you think they will mess up the install of my spoiler? It sounds like the kit comes with quite detailed instructions and a template. Im just a worry wart! I just paid 15,550 for my B and now Im hoping all the accesories are put in right (Spoiler, fogs, bumper aplique, sub)
any futher insight is appreciated...
sIcKsCiOnS
sIcKsCiOnS
holy moly thats neat! I hope they dont mess it up!
The nut insert (which i called Threaded Inserts) is exactly what i was talking about. However, i heard that it didn't seem to hold the spoiler tightly as it should cuz the metal sheet is pretty thin...and it sort of wobbles the spoiler.
As for the CF spoiler... contact Nilo (XBBOY) or Adrian (scioninla) for pricing @ Scion Sport Tuning...they carry them, i think they have couple in stock right now.
LzeroKI
Scion tC 1G Aero & Exterior
02-05-2015 06:09 PM
