I need Ur Help Fast!!!!!
I bought some aftermarket fog lights and i wanna wire them up to the stock wiring harness. the only thing is is that i need some relay that goes in ur fuse box. anyone out there have Aftermarket fogs know where to get this relay. i looked in the tech fourm and all it shows is the stock fog light kit, no aftermarket stuff. Any help would be good, thanks.
if your tring to use the factory wires an such, you'll need to get the relay from the dealer...
they have a special 4 pin relay....
it goes in the fuse block under the hood....
I may be way off on this one...but I don't think you need to use a relay. I believe the relay is used to turn the fogs off when your hi-beams are on. I'd prefer to have the fogs on even with the high beam on. I would just buy the stock switch, and wire it to the fogs.
the kit that i bought has a switch that comes with it but its a 3-prong switch and the stock switch is a 2-prong. i tried to wire it all up and see if the fogs would come on, but it didnt work. i have to go in for my 5000 mile service on wednesday, so maybe ill just call and get that relay. i was just wondering if it could be done without the relay. i guess no one has wired up aftermarket fogs using the stock foglight harness. if so let me kno.
carid
02-10-2019 10:46 PM
RokGoblin
08-11-2015 02:45 PM
danaxb
08-10-2015 06:33 PM
