LED DRLs?
LED DRLs?
What do you think of this? / Has anyone tried this with the B on the grills or oem fog slots?
(MS Paint in the mid grill ftw)
I really like the idea of using LEDs as an energy efficient yet stylish way of having daytime runners. Think Audi R8, and also LED halo/angel eyes
PIAA Deno kits: http://www.piaa.com/LEDs/LEDs.html
http://blog.goo-net.com/car_life/img/8/06_l.jpg
On a Nissan: http://blog.goo-net.com/car_life/img/8/05_l.jpg
Hmmm. Maybe try to put it in the top grille.
I'll be doing something similar soon. There's a small opening in the headlight to the left of the bulb. A 5mm LED fits in there, and I plan on wiring it to the parking lights.
i did the same thing through the small hole next to the headlamp bulb..used 5mm blue led bulb that are hooked up top my alarm and paking light using a diode ...bright ___ hell at night either soid blue ar flashing with the alarm..
I did something similar, but in the next grill down.
https://www.scionlife.com/forums/vie...r=asc&&start=0
I don't have that setup any more. A little mishap and lost both sides. Didn't replace them.
Should work fine. You could go with a narrower angle LED, which will be brighter. Being farther up will make them easy to see. I ended up going with a wider angle LED, which was less bright. To the eye it looked brighter, cause you could see it at every angle. With the narrow angle it looked dim until you looked at it head on and then they were really bright.
SJMiller
09-12-2015 07:33 PM
