Rear Tail Light Fixture Removal
Would someone please give a brief explanation on removing the fixture(s)? I have replacements and don't want to hurt anything going into it. Didn't see anything in the tech section. Thanks.
you need a 10mm socket. just remove the panels in the trunk. Then you feel 2 nuts, use the 10mm socket and preferably a small ratchet, to take the 2 nuts off. Then it's easiest to remove either the middle bulb or just the wire from the middle bulb. and you're done! switch them out, put the bulbs in and tighten the screws back up!
xBSciontist
06-18-2019 03:06 PM
TheTripleC
01-04-2015 06:46 PM
mrbadass03
24
04-21-2004 02:17 AM
