Searching high and low: Clutch install DIY
Old 01-06-2010 | 06:02 PM
cingham's Avatar
Question Searching high and low: Clutch install DIY
I found this one for TC: https://www.scionlife.com/forums/sho...d.php?t=138067
but I'm looking for one done for the XB? Anyone know where I can find it? I've done clutch replacements on cars with cable transmissions, but never did it with one having a hydraulic clutch.
Need something I can study to make this a quick job; I can't be with out my car. Taking it to a shop is not an option (unemployed and full time student)~!
Old 01-06-2010 | 07:33 PM
MadMike550's Avatar
if you have experience with front wheel drive clutch replacment..do not sweat the hydrolic clutch...very simple
Old 01-06-2010 | 07:55 PM
cherry-8's Avatar
There's a little info in this thread:
https://www.scionlife.com/forums/sho...clutch+install
I haven't changed an xB clutch.
Last one I did was an A1 Jetta GLi, dropping the tranny out of the bottom of the engine compartment.
Good luck with it if you do it yourself,
cheers,
MD
Old 01-06-2010 | 08:14 PM
cingham's Avatar
It has to be me that does it. I'm right now taking two winter-term classes so when they are over next week I have a weekend to do the job. Other wise money that would be spent on labor will be going towards my test prep for my Nursing Degree (BSN) and classes.
If anything I'll try to do a photo of EVERYTHING so that someone later on will never have to go through this endless crappy search.
I just don't know anything about hydraulic clutches other than it uses fluid system. I'll read what I can, but other wise I'm ***** to the wall on this one...do or die.
Old 01-07-2010 | 04:16 AM
sdsnybny's Avatar
Have you tried the Toyota OE shop repair manuals, they can be downloade from zip files free here Scion Document List
you need these basically
1) clutch componets (torque specs and blow up of parts)
http://scionlife.org/Scion_Docs/2004...t/conponen.pdf
2) clutch overhaul/replacement
http://scionlife.org/Scion_Docs/2004...t/overhaul.pdf
3) transmission componets (torque specs and blow up of parts)
http://scionlife.org/Scion_Docs/2004...y/conponen.pdf
4) transmission overhaul/replacement
http://scionlife.org/Scion_Docs/2004...eplacement.pdf
Old 01-07-2010 | 02:30 PM
MadMike550's Avatar
do you know anything about brakes?
the hydrolic clutch works a lot like your brakes work
this might be easier if you just ask the questions that you have..
I'll be happy to answer them...
send me an e-mail to MadMike550@aol.com put xb clucth in the subject line
I'll do what I can to help you
Old 01-07-2010 | 03:52 PM
cingham's Avatar
sounds helpful probably won't get to asking you any questions since I'm going to be locked in a library for the next 72 hours....taking two mini term classes (6 credits) in two weeks...yeeeeaa sounded good on paper
Old 01-07-2010 | 05:48 PM
MadMike550's Avatar
good luck with your classes...if and when you need help
just send an e-mail
Old 01-07-2010 | 07:01 PM
cingham's Avatar
Just picked up 2004 SCION XB 1.5L 1497cc L4 FI [1NZFE] SACHSK7007903 (K70079-03)Clutch Kit$ 112.79$ 0.001$ 112.79 Discount $ -5.64 ShippingGround (FedEx or UPS)$ 10.39
while on break
Old 01-08-2010 | 06:58 PM
daneisthegreatest's Avatar
is there a haynes manual for our car yet? possibly pick one of those up
Old 01-14-2010 | 11:40 PM
cingham's Avatar
there is no Haynes available for our cars at all. Tomorrow I have my four hour final and an essay so this weekend I'll get to it. I have a camera and a photobucket account that has been around for 5+years, I'll see what I can put together.
Old 01-30-2010 | 05:07 PM
cingham's Avatar
I e-mailed haynes also and they sent me a reply stating that they have "no desire to make a manual for our car"
archael666
03-20-2019 12:52 AM
randomsuper
20
06-13-2015 11:56 AM
hotroddelux
12-04-2014 12:33 AM
eric_m
79
03-17-2013 01:21 AM
TheRedBox
31
12-02-2003 05:53 PM
