Towing Update
Towing Update
I just wanted to share my thoughts on towing with the xB, since I've been doing it all summer now. Over the winter I purchased a 50" Harbor Freight trailer and a Curt Towing hitch for my Box. I modified the trailer by installing steel rails to account for the +70" contact patches of the bike wheels. This essentially extends the tailer 15" on either end exactly where it is needed.
Since I have been towing with the trailer, two dirt bikes, two adults and all our gear, I have not had any issues whatsoever. In fact, this past weekend I drove from Seattle to Ellensburg via Interstate 90. I averaged 80 mph, occasionally dropping down to 75 mph on the steeper parts of the mountain pass. IOW, I was out in the left lane hauling ___ while many other vehicles were chugging along like an asthmatic in a hay-field.
I also hauled my fully-loaded rig through the National Forest on gravel access roads, carrying 40 to 50 mph through a lot of turns. The traction control comes on frequently, and it really helps keep things under control. I did have the trailer wagging back and forth a few times as I powered out of turns, but the car was always perfectly behaved.
I was initially worried that I would bottom out -- especially with my Koni shocks (yellow). I set them to the middle setting, and they seem just fine. I have never scraped anything and there is no weird bouncing at the hitch. The only downside to my towing setup is that my gas mileage suffers when I drive over mountain passes in excess of 60 mph. At 80 mph with a full load, I got less than 25 mph. This is more a factor of aerodynamics, IMO, but the added weight doesn't help.
Originally Posted by Easyoboe2
Is this April First?
Re: Towing Update
Originally Posted by peckhammer
... purchased a 50" Harbor Freight trailer and a Curt Towing hitch for my Box... have been towing with the trailer, two dirt bikes, two adults and all our gear, I have not had any issues whatsoever....
I figured that trailer and load would be OK, but I am surprised at your towing speeds. Not what I would do even with our 1991 Mazda 2.6L truck. If our boat sells, the truck might go, too, because this only remaining load can be handled by putting a hitch the xB:
http://aatherton06.home.insightbb.co...railerSolo.jpg
For keeping an eye on the engine temperature while towing, the ScanGuage would be useful in giving more warning than the red ight:
http://s49.photobucket.com/albums/f2...B%20ScanGuage/
You must have the 5 speed manual. The 4 speed auto gave me issues on the mountains in overdrive. Unless... you were driving thru all these places in third gear! Yikes!
Have you checked your brakes? Do the rotors look scorched?
How much tongue weight do you have on there? did you do the bathroom scale weigh-in?
Originally Posted by scionBoy86
do u have a manual or auto transmission??
would i be able to pull a wave runner with this hitch???
Re: Towing Update
Originally Posted by vintage42
How did you connect the wiring, or did you have a shop do it?
I then spilced into the tail lights and ran the wires our of those access panels. Very easy to do.
Good Job !!
I've towed with mine also. No problems !! I have the fold-up 4 by 8 foot trailer from Harbor.
The key word is resposible towing. A 50 foot trailer would be a NO-NO. You would probably leave your tranny behind doing that. But a 50 inch with 2 bikes is probably OK. I've already done a fridge with no issue.
PS.... Nice Trials Bikes. That's tough to learn correctly.
Re: Towing Update
...For keeping an eye on the engine temperature while towing, the ScanGuage would be useful in giving more warning than the red ight
(I don't know at what temperature the red iight comes on because I have never seen it.)
I'm sorry for being a smart a__. I mis-read your 50" trailer for 50'. Can you imagine pulling a 50 footer?
I like that ScanGauge... Where would I come across one of these? I do not tow anything but I am always nervous about engin temp. for some reason. I do not like having a red light that says, "guess what? Too late!" On top of that I think I f*&ked up my speedo needles when I changed my gauge backlight color..hahaha
Originally Posted by fokusco
...I like that ScanGauge... Where would I come across one of these?...
My 2 cents to towing.
I got and installed the curt trailer hitch today for my XB. Installation went pretty smooth. getting over the exhaust was a pain, and then of course the holes didn't line up 100% so I had to push out the driver side while trying to start the bolt. a second pair of hands would've been nice.
I installed with the help of a floor jack, which I would say at least a jack is neccessary. A lift would've been great!!
Wiring was a bit tricky because I wanted everything kept inside so it was hidden when not in use. I'm able to just pull it out and leave it hanging out the back hatch when towing, and put it in the storage bin when not in use.
anyway I have a snowbear trailer that weighs about 500lbs or so. ( 8x6 )
I pulled it around the block, and then down the highway at about 55mph and it was almost not noticable. Of course it was empty; but I was pleased. all I'm going to haul in it is dive gear or my banshee.
I'm thrilled with my XB and even now more pleased because the added versatility.
Towing Update
So far this thread has only discussed the xB's ability to be a cargo hauler. I would like to add a link to the Club xB's discussion on the xB as a camper hauler as well... http://www.clubxb.com/forums/f2/1777-scion-xb-trailer/ .
There are pictures of xB towing a teardrop camper and (on page 3) some links to suppliers of campers and cargo haulers. Probably the most useful link to lightweight trailering equipment is... http://www.webbikeworld.com/motorcycle-trailer/ .
I'm wondering if this would work:
http://www.scandipacific.com/index.p...d=43&Itemid=43
Any opinions? I want to get a dirtbike and i don't want to have to buy a trailer that tows 3 bikes when i only have one. However i noticed that the Curt Hitch has a Tonque weight carrying capacity of 200lbs.
So i'm thinking that sine bikes are like 200+lbs and the "Motorcycle Carrier" probably weights like 50~lbs, so it won't work right?
I had my thread of my trip to alaska hauling a HF trailor, 2 truck bed boxs mounded on it. Pulled a total of roughly 800lbs. Went 4500 miles pulling it, and at one point got 36 MPG.
https://www.scionlife.com/forums/vie...highlight=4500
