xB Rear Sidemarker Lights
Old 08-10-2004, 11:09 PM
Guest
Guest
Posts: n/a
Default xB Rear Sidemarker Lights
Are clear rear sidemarker lights available for the xB?? I havn't seen any specifically for it, or a close match from another toyo product. Anyone???
Old 08-10-2004, 11:11 PM
debris's Avatar
good luck ...ive been looking forever....anyone know what we dont?
debris is offline
Old 08-11-2004, 12:02 AM
Old_Punk's Avatar
I went out and poked around my xB to see how the rear markers are installed. If you crawl under the car a bit you can see the back of the lights and the wiring. Seems to me they're easy enough to pop out and unplug. Once you do that, you should be able to take about any other clear marker light that's big enough to cover the hole in the bumper and attach it with double stick foam tape. I wouldn't be surprised if the front fender lights plugged right into the hole and the wiring harness. If not, there's a good chance some clear markers made for another Toyota would fit.
Oh, and I saw some clear marker lights a Pep Boys last Saturday.
Old_Punk is offline
Old 08-11-2004, 12:07 AM
phatboy's Avatar
I was thinking about this subject the other day. I was wondering if you got another set of front fender sidemarkers, how hard it would be to put them in place of the rear sidemarkers, but using a red bulb.
Thoughts?
Joe
Scinergy IA
phatboy is offline
Old 08-11-2004, 04:36 AM
JdMBboFSD's Avatar
Default ummm
keep me posted.....i would like to know as well.......
JdMBboFSD is offline
Old 08-12-2004, 03:10 AM
windowtint's Avatar
You can get to the back of the light easier if you just remove the 10mm bolt on the edge of the wheel well holding the bumper flange in place. Pull the bumper back and you can acces the single bolt/washer combo on the back of the light.
Take note though, the hole that the light goes into is nearly as big as the light too. Small lights like the fender mounted directional light aren't going to work for obvious reasons
windowtint is offline
Old 08-12-2004, 04:07 AM
AleXb's Avatar
i want smoked rear sidemarkers :D
-Alex B.
AleXb is offline
Old 08-12-2004, 04:28 AM
windowtint's Avatar
well, easy enough.
1 10mm socket or wrench
1 can of smoked taillight spray from FoliaTec, NOPI, local rice shop, wherever
take out lights, spray till they're dark enough for you, reassemble.
A LOT easier than tracking down interchangable clear markers.
Old 08-12-2004, 11:59 AM
Old_Punk's Avatar
I stopped by the parts department while I was at the Toyota dealer yesterday and asked the price on the front fender marker lights. After he pulled it up on his computer, he showed me there were two parts -- the lens assembly (#81731-51021) and the bulb socket that plugs into the lens (#90075-60005).
From my brief look at the diagram, it looks like the front fender markers COULD be a direct swap with the rear markers.
The way to find out would be to pop out the markers on your car to see if it works. I haven't tried accessing the fender markers yet, but you must be able to get to them in order to replace the bulbs. The question is whether there's anything holding them in place, like adhesive, our whether they're just held by prongs.
Old_Punk is offline
Old 08-12-2004, 12:09 PM
WFO
N.G.S.O.
WFO's Avatar
Default go
take out inner fender plastic :oops:
WFO is offline
Old 08-12-2004, 12:18 PM
Old_Punk's Avatar
Originally Posted by windowtint
well, easy enough.
Um, but that gives you smoked lights instead of clear.
Old_Punk is offline
Old 08-13-2004, 03:26 AM
windowtint's Avatar
uhhhh... welll... yeah??!!??
That would make my directions an appropriate answer to AlexB's post directly above mine where he said
-Alex B.
Also, the front side markers will NOT work on the rear bumper marker location. The hole that's behind the red marker light is BIGGER THAN the clear front fender lights..
Unless you don't mind doing some plastic-welding work and painting to shrink the hole, it aint gonna work (I've physically checked).
The rear marker light "problem" will either be 1. waiting for someone to make them, 2. casting your own one-offs from Castalite in a mold (WORK), or 3, the easiest, ind a lens from a different car that fits and looks good.
Old 08-13-2004, 03:34 AM
JdMBboFSD's Avatar
Default umm...
thanks windowtint.......will be doing that soon....
Old 08-13-2004, 12:08 PM
Old_Punk's Avatar
"Also, the front side markers will NOT work on the rear bumper marker location. The hole that's behind the red marker light is BIGGER THAN the clear front fender lights."
I was afraid of that. Thanks for the info. You saved me some work.
Old_Punk is offline
Old 08-15-2004, 06:21 AM
krazylowgsx's Avatar
i'msetting out on a mission monday to find some clear lights that will work. i'll let you guys now what i find!
krazylowgsx is offline
Old 08-15-2004, 06:49 AM
Music City Scions
bB2NER's Avatar
OK let us know what you find out THANKS!
bB2NER is offline
Old 08-15-2004, 01:22 PM
Old_Punk's Avatar
I noticed 4 styles of generic/universal clear side markers by APC at the auto parts store. I didn't have anything to measure with so I don't know if they were large enough to cover the hole in the bumper.
Old_Punk is offline
Old 08-15-2004, 02:35 PM
Alan's Avatar
It would be nice if someone out there made some marker lights that were a little more flush fit to the bumper. The stockers really stick out. I'm going to just give the Night Shades a shot. My car is pretty much black anyways, so hopefully they will blend in a bit more.
Your other choice is just remove them all together and fabricate some sort of cover plate and paint it body color.
Alan is offline
Old 08-15-2004, 03:05 PM
phatboy's Avatar
I've decided to make a paint mask that has the bB logo on it and paint the rest of the markerlight body color. That will still accomplish the basic look I'm going for until something better comes along.
Joe
Scinergy IA
phatboy is offline
Old 08-15-2004, 03:52 PM
Music City Scions
bB2NER's Avatar
Hadn't really thought about doin anything with em up til now but my curiosity has peaked and it's time to modify
bB2NER is offline
Quick Reply: xB Rear Sidemarker Lights
