xb windshield problems
Old 01-05-2005, 03:22 AM
George's Avatar
Default Re: xb windshield problems
Originally Posted by rallyxb
I don't know about that . My 82 CJ-7 Jeep had an almost 90 degree windshield. I drove it for 6 years and hardly every got a stone chips. I often wonder if the newer windshields are just weaker.
The height of the CJ windshield is considerably more than the xB. I find that my VW bus takes considerably fewer pebble hits than the xB, but a lot of pebbles hit the front sheet metal below the windshield.
George
George is offline
Old 01-05-2005, 05:18 PM
Guest
Guest
Posts: n/a
We are of course a course a brick on wheels you know. Also the winsheilds on our cars are lower than any jeep too. Its just gotta be the design of the angle. I too was one who got the windshield replace the first weekend I had it. :sad:
Old 01-06-2005, 03:25 AM
oh1101's Avatar
Originally Posted by TOAST3R
a lot of people have had chipping issues and such. i have a real tiny chip on mine also. i think it also has to do with the angle the windshield is at.
rocks cant just hit it and bounce over as easy as a more slanted windshield. same with bugs, if you notice the windhsield collects bugs real easy. my other cars ive had never had a problem with bugs, but they were all slanted a lot more
i also have a 97 jeep wrangler and i don't have a single chip in it's windshield.. rocks bounce off, but dont leave a chip. this is one reason i posted the message in the first place because i really question the quality. you would think that they would fix a problem like this and it would go thru extensive tests before manufacturing..
oh1101 is offline
Old 01-06-2005, 04:00 AM
xBabe's Avatar
phew! im not alone. i have a mysterious 7 inch crack. it appeared one morning.
xBabe is offline
Old 01-06-2005, 03:33 PM
TJ
TJ's Avatar
Originally Posted by scion619
yah I just got my whole windshield replaced last week... $371 bucks... dam there expensive
scion619
Yeah 310 here. I didn't think the rubber moulding needed to be replaced or else it would have been cheaper. I should have known. I just don't want to replace it anytime soon (Cross my fingers)
don't follow contruction semi's.
TJ is offline
Old 01-06-2005, 06:27 PM
ayS
ayS's Avatar
i got a bullseye on my windshield. i think the angle of the windshield has alot to do with it. like someone mentioned above. we are a moving brick wall in some sorts.
ayS is offline
Old 01-07-2005, 12:14 AM
MicWeb_xA's Avatar
I had the same problem with a Golf - it got several chips. Windshiedl angle. None on my xA - very sloped.
I did find that keeping the window clean and treated with Rain-X helps a little. It's like wax to keep rain off, and the rocks slip a little, bite a little less. But it won't cure the problem, depening on how hard the windshield gets whacked, and other factors (like is the windshield clean and slippery, is it a smooth piece of gravel or rough edged, the speed).
MicWeb_xA is offline
Old 01-07-2005, 02:44 AM
rallyxb's Avatar
George
Hmmmm... If it's an aerodynamics issue, do you think a bug deflector would solve the problem?
Anyone here with a bug deflector that is still getting stone chips in the windshield?
rallyxb is offline
Old 01-07-2005, 02:52 AM
stupidriver's Avatar
I heard that these two morons who were married were driving one day and they had had a chip in their winshield and it had spread. Too bad they were sooo damn stupid that it fell in on them.
stupidriver is offline
Old 01-07-2005, 04:05 AM
erichlf's Avatar
Well my windshield just cracked after only having the car 2.5 months.
erichlf is offline
Old 01-07-2005, 12:45 PM
pileofmonkeycrap's Avatar
Got my first windshield chip last night from a rock. Luckily it's real low on the glass. It's about 2" above the end of the driver's wiper. Sitting in the driver's seat, it is slightly to the left and above the speedo.
pileofmonkeycrap is offline
Old 01-08-2005, 12:14 AM
wooish's Avatar
Just got one right now while driving on the highway. My xB is only one week old.
wooish is offline
Old 01-08-2005, 01:43 AM
xBChef's Avatar
I also got a chip. Tried one of those windshield repair kits from the auto parts store. It actually worked really well. There is just a tiny mark where the chip was.
xBChef is offline
Old 01-09-2005, 05:08 PM
ScionMikey04's Avatar
Originally Posted by oh1101
I have had my xb for about 3 months now. My xb was delivered with a chip in the windshield, so a new one was installed at the dealer. Earlier today I now got the 3rd chip in my new windshield. What is going on? I have never had problems with "windshield quality" in my other vehicles for the past 10 years I have been driving. Are these windshields of lower quality or am I just having really bad luck? Is anyone else getting rock chips pretty easily from just passing cars?
Yep,it chip's pretty easily.I currently have 3 chip's in my winshield 2 at the base of it,1 to my left side half way up.I think it has alot to do with the windshield angle and a lower quality glass then say what's used in a Camry or other Toyota product.I believe alot of people with Scion's have problem's with rock chip's.
04 Scion Xb RS 1.0 #0686 of #2100
17-inch Black Motegi Racing RT-5's with Toyo Proxes All-Season 215/40-ZR17
AEM Cold Air Intake
PrecisionMuffler.com axel-Back
Amsoil Synthetic Lubricant's
The Box is pretty much loaded out.
ScionMikey04
Let's just all try and get along and live in peace.
ScionMikey04 is offline
Old 01-10-2005, 01:54 AM
rallyxb's Avatar
F.Y.I.
JC Whitney now sells a DYI Clear Paint-protection Film at a fraction of the cost for a professional install. I think with some patience anyone could do an install on the front edge of the hood and bumpers. I will do my xB when it's warmer in the spring.
Here's the info...
"... UV protected--won't yellow over time. Simply clean painted finish, then apply the film. Flexible urethane film can be stretched and molded to fit your vehicle's curves and angles; won't shrink. Film can be repositioned throughout the installation process until adhesive sets. Adhesive removes with product (even after years) and leaves no residue. No special care needed; wash and wax vehicle without damaging film. Includes everything needed for effortless application..."
4" x 6-ft. Roll Clear Paint-protection Film
Price $26
Part# ZX518938A
8" x 6-ft. Roll Clear Paint-protection Film
Price $41
Part# ZX518939R
http://www.jcwhitney.com/autoparts/C...&searchbtn.y=0
rallyxb is offline
Old 01-10-2005, 05:08 AM
George's Avatar
Yeah those kits are pretty good. I've used them several times and, while they don't make a perfect fix they have prevented cracks from spreading.
It's _really_ important to fix rock chips ASAP and definitely before _any_ water gets on the chip. If I can't fix the chip immediately I put a little square of electrical tape over the chip to keep water out. If water gets into the crack, you can't get it out!
Also important is to read and follow the instructions exactly. The resins used in these kits are a bit touchy, but if you follow the instructions they work well.
One thing that I never do with any repaired windshield is to spray it with hot water in winter or cold water in summer. The expansion and contraction will really make the cracks run!
George
George is offline
Old 01-10-2005, 05:43 AM
ThunderGod's Avatar
any xB's out there w/ those rock/bug deflectors on their hood?
will that help also from deflecting rox to the windshield? or is it just for the hood?
anyone.
ThunderGod is offline
Old 01-10-2005, 12:45 PM
vanhate's Avatar
I have three chips in mine. Wife has about 5 in her TrailBlazer over the same period of time. I don't think it's anything terrible. It just happens.
This past Thursday I was driving home and a huge chunk of ice came off a truck and hit my windshield. It was larger than a softball. Sounded like a shotgun going off, but the windshield just bowed in and back out and it bounced off. I say these are pretty durable windshields that a good five pound chunk of ice would just bounce off.
vanhate is offline
Old 01-10-2005, 03:02 PM
turbocivic's Avatar
We've not put a windshield in a Scion yet.....stay out from behind dumptrucks...lol
turbocivic is offline
Old 01-10-2005, 06:12 PM
Having my chip fixed tomorrow at work by a local place that goes mobile. $60 with a warranty that the chip won't spread further. I'll post the results with before and after pics.
Quick Reply: xb windshield problems
