Developing Fiberglass Grilles
#42
True lots of people get towed... That's why i said "I" dont plan on getting towed... and IF you do get towed it is by a truck that will go under the car... Those front end Rice tow hooks are for race cars that get towed in the pits... and since 99.9% of the xB owners on here are DD it makes little sense to have it... UNLESS you are doing it for looks/JDM styling and if so best of luck with your ricer....
/end rant
/end rant
#43
Originally Posted by ShaffNasty
/end rant
BTW, I have seen the hook used to pull (drag ) a car that was parallel parked between two other cars out to where the truck could get to it for a normal tow hook-up.
I know, I know...
#53
Figured I could at least get a picture up. It looks pretty rough, but basically this is the back of the grille, I'm working on getting it all smoothed out so that the grille sits perfectly against the front bumper. Once, I get passed this part, I'm going to shape the curve in the front, and then move onto the vents. Once I'm done shaping the foam, it's getting hit with body filler and sanded down smooth.
#57
Originally Posted by CIONIDE
Why are you putting floral foam on your face?
J/k. I was building a one off fiberglass for a Civic. Floral foam as the base, then use fiberglass to lay over it, body work, paint, done.
#58
I love flowers THAT much. :D
Good thing you didn't get fiberglass on your face... I hope.
Threadjack alert
#60
Floral foam, I assume?
Ugh. I hate that stuff. Get it on your hands, try to get it off, doesn't come off. Get it on your face, can't get it off, gets in your mouth.
Blech.
Blech.
