HELP! Use of clay on paint before waxing
#81
Its thick and has a little gritty feel to it. I seriously don't know why you keep recommending something that is 30 dollars for a big bottle that he most likely won't ever use before it goes bad. He can get a smaller/cheaper bottle of the OTC stuff and be just as happy. Another thing that is wrong is your advising him to use the most aggressive product out there when his real problem is the buffer he is using.
#82
I dont think the buffer is the problem. It has been debated many times whether hand vs buffer is better. It mainly comes down to the solution. I think m105 is worth it on every level. It gets the job done at an efficient rate. I have used the Meguiars Scratch X 2.0. Good product but just doesnt cut it for me. It takes me an 1 hour to 2 hours to detail my hatch with scratch X but with m105 it takes me 30 minutes. Also your advising him on upgrading to a new buffer which cost more then 30 bucks.
#84
The problem is the orbital buffer. It simply doesn't have the power to remove defects. Look into buying either the Flex, G110 or PC 7424XP and some lake country pads. Its the best investment you could make to keep your car looking good.
Remember try the lightest polish then work your way up to a more aggressive polish if need be. Just don't start out with something like M105.
#85
He's using an ORBITAL buffer thats completly different than by the DA buffer you have aka G110. Everyone knows by DA or rotary is the only way to go. You can work by hand but it takes longer and takes alot more out of you. I have done cars by hand and it takes me twice as long as it would with a DA buffer.
You can also change your pad so you get more or less cut. Do you inspect your work under lights?
#86
Do you know how to use the rotary buffer? If not just get a DA and buy a junk yard hood to practice on with the rotary.
To finish down correctly you would need M205 if you are going to be using M105. M205 would be the polishing step then you would wax after done with that.
#87
I wouldnt say you NEED M205. In my opinion this product is overrated and not worth the money. I have it and regret buying it.
#88
#89
#90
I followed no ones instructions and went to town with my current products. I used swirl remover, scratch x 2.0, Ice clay stuff and Deep Crystal carbauna wax. I figured I might as well use some of my products. It made a HUGE difference. I cleaned it first, then used Scratch X. That made an improvement, then I switched to swirl remover, and that made an even bigger improvement. Every time I did another section, the rest of the hood looked like crap compared to the section I just did. Then when I used that liquid clay trash and washed it off with water. After it dried, the hood looked like crap again, so I said ____ it, used the wax and when I took it off, the hood was a nice deep black and looked wet. The blemish is still somewhat there, but it's even better. I didn't even use a standalone polish and the hood looks pretty deep.
Pics in a little bit.
#91
Alright.
I decided to actually tape off sections so I could see the improvements as I went along.
This is after using Scratch X2.0 with an orbital buffer and a terry cloth applicator. As you can see, there are still TONS of swirl marks, but those aren't my concern right now, the massive fading is. The Scratch X helped a lot.
This part of the hood wasn't as bad. I decided to switch to Meguiars Swirl Remover. It's a very light cut, so I knew it wasn't going to remove my swirl marks, but I wanted to compare its ability to get rid of the oxidation to the ScratchX. Results are basically the same.
This was the worst part of the hood. It's still pretty bad around the nozzle, because the buffer I use is 10", so nothing was even getting to this part, but the entire hood used to be like that, with the center of the hood much worse.
And the finished product, after waxing. I didn't use any polish or glaze.
#92
#93
Yea your Honda is in pretty bad condition. You can remove 60 percent of the swirl marks with one round of m105. I do not think m105 is too aggressive for your paint. Actually I would say its right in the ball park. You might as well experiment with the m105 since your skipping steps.
#96
edwinisdumb15
Regional - Pacific South
09-13-2015 12:44 AM
