How-to: Black Headlight Mod
Old 09-26-2008 | 04:40 AM
08SWbox's Avatar
Default How-to: Black Headlight Mod
Just thought i would make a simple writeup with a few pics so that everything about doing the BHLM is much clearer.
Tools needed:
10mm socket
flat screwdriver
phillips screwdriver
oven
Materials used:
1 can of Krylon Fusion paint (your choice of color)
*optional* black or clear silicone
step 1:
Remove the clips holding on the heat plate(piece above grille and connected to radiator support). This is dont by pushing in the center of the black clips. After they are all unclipped, simply remove the shield and set it aside.
Step 2:
Remove upper grille.
this is done by removing the 10mm bolts and some clips on the top part of the grille. These clips need to be removed with a flat screwdriver by prying lightly on the clip to unclip them. The grille will need a slight tug forward to pull out of the bumper.
here is a picture of the head plate and an idea of what needs to be taken off.
-RED circle is a clip that you push the center in.
-Blue circle is a clip that needs to center popped out using a flat screwdriver.
-FULL Red circle is where the 10mm bolt that holds the headlight on is located under the bumper.
Green circle is a 10mm bolt that needs to be removed to pull the bumper away so you can access the bolt holding the headlight.
Step 3:
Remove 10mm front bumper bolt inside of the wheelwell holding the bumper to the bracket.
There is also a 1/2 turn plastic screw further down the bumper that needs to be taken off. This is done by using a flat screw driver and turning the clip 1/2 turn then pulling on it to get it completely out of the piece holding it.
step 4:
Tug on the front bumper from the wheel well. You will hear some snapping. DO NOT PANIC! this is just the bumper bracket uncliping from the bumper.
step 5:
After the bumper is moved away from the fender, you will se a bolt recessed in the black bracket that was holding the bumper on. Remove that 10mm bolt.
Step 6:
Remove the bolt that was shown in the picture as a FULL Red circle. Then remove the bolt holding the top of the headlight to the fender(in the engine bay).
Your headlight should now be free to move around. Gently work with the light and be careful to not scratch the lens on any parts of the car.
After the headlight is out of the "pocket" unclip all of your lights along with the white clip that holds all the wires nicely to the back of the headlight body.
Repeat steps 3-6 for the other side of the car.
after the headlight is out of the car, do whatever you need to do to get any sort of contaminants off the lens.
I used clay from a clay bar kit and it worked very very well.
Step 7:
Preheat your oven to 305*
while the oven is preheating, go ahead and remove the rubber seals on the back of the headlight and take out the 3 phillips screws that are along the back edge of the light. There are 2 brackets on the bottom of the light that the bumper clips into. These are removed by a single phillips screw.
Step 8:
Once the headlight has been "stripped" of all the loose parts, you are now ready to bake them.
Get a piece of cardboard that will fit inside your oven and that the headlight can safely rest on without touching the rack in the oven.
***TURN OFF YOUR OVEN***
once the oven has been turned off, place the headlight in ontop of your piece of cardboard.
Leave the headlight in the oven for 8-9 minutes.
Step 9:
After your timer goes off, get some oven mits or towels to handle the headlight with as it will be warm.
Have someone hold the light for you while your use a flat screwdriver to slowly pry the light apart. Make sure you concentrate on the clips that are holding the lens on. Start at the part closest to the signal light and work your way out.
Once the lights are apart you should have this..
This is the back part of the light. Lens and center section are removed.
Repeat this step for the other light.
Step 10:
Remove the 2 phillips screws that are holding the chrome center piece to the lens. Then lightly pull the chrome piece out of the lens.
Remove the reflector using a flat screwdriver and pressing on the "tab" that is holding it in.
Set the lens aside here it can not get any damage done to it and noone will touch the inside of it.
Be careful to keep your hand off the actual chrome part of the light. This is where you will be painting and if there is finger prints on it, the paint wont stick.
Step 11:
Paint the center section of the light. You should make sure you coat both of them evenly and be sure to get every area that is chrome.
When the painting is done, you should have something like this:
In that picture, i had tinted the reflector. You can leave it amber, tint it, black it out, or leave it out.
Step 12:
Once the paint has cured, put the reflector back in and carefully slide the newly black(of whatever color you choose) back into the lens.
Once it is seated correctly, put the 2 phillips screws back in.
Step 13:
Set the lens and back piece together making sure they are lined up and lightly press them together. Before putting them together, if you would like, you can run a small bead of silicone in the groove where the lens sits just so you can be sure they wont get condensation inside.
Preheat your oven to 305* again
once preheated TURN IT OFF and set the light inside for 5 minutes. This gives the silicone a chance to soften up and make it easier to reseal the lights.
After pulling them out of the oven push them together (this might take some muscle). Make sure that all of the clips are clipped from the lens to the back housing.
Step 14:
Its time to wrap it up!!
Reinstall all of the seals and screws that you removed from the light to get it apart.
Put the headlight back in and put all of your clips and 10mm bolts back in their places.
Here are some pics of the finished product on a Super white xB2 and a BSP xB2.. day pics of the BSP coming soon...
Old 09-26-2008 | 04:56 PM
joeyjoexb's Avatar
i kinda want to color match mine to my sw i think it would look really good
Old 09-26-2008 | 05:36 PM
miketf1's Avatar
good job with posting this up.. i actually used a guide i found on a rsx forum.. it worked but when i did the rsx one i found that their clear lens total ____. it discolored on its own after i threw it in the oven.. WEAKKK
Old 09-26-2008 | 08:08 PM
08SWbox's Avatar
The reason that the RSX lights do that is because its honda and they use cheaper plastic than toyota does :D
Old 09-27-2008 | 12:10 AM
xseveredveganx's Avatar
Utah Scions
Vertex did this. It looked alright, but not for me. :D
Old 09-27-2008 | 12:39 AM
08SWbox's Avatar
I would have color matched the lights but im going full on panda style and i dont wanna look like a Honda Fit
Old 09-27-2008 | 04:14 AM
08bspxb's Avatar
dont color match like the honda fits do!!!! white is ugly for headlights ;P
Old 10-04-2008 | 09:17 AM
stuckpig9's Avatar
i volunteer you to help me do this. ha
Old 10-04-2008 | 09:20 AM
08SWbox's Avatar
no problem man, i will help you out with it..
You just give me that CF hood and we will call it even lol
We gotta set up a SM mod day..
Old 10-04-2008 | 09:24 AM
stuckpig9's Avatar
haha.
yeah.
an install day would be cool.
i wanna remove the squirrel finder too.
the meet was cool?
Old 10-04-2008 | 09:29 AM
08SWbox's Avatar
squirrel finder is super easy once the headlights are apart.
The meet was fun, you shoulda been there
Old 10-04-2008 | 09:31 AM
stuckpig9's Avatar
i wanted to go. i usually work nights and for sure weekends unless i ask ahead. so youre from corona. i used to stay with my aunt right by the spectrum and ayala in chino hills. thats kinda close right?
Old 10-04-2008 | 09:59 AM
newtc4me's Avatar
good write up.
Old 10-10-2008 | 03:58 AM
XD40tC's Avatar
Eh i dont like it.
Old 10-10-2008 | 07:47 AM
CIONIDE's Avatar
Originally Posted by XD40tC
Eh i dont like it.
Then don't do it.
Old 10-10-2008 | 07:49 AM
curtislo9's Avatar
Owned.
Old 11-13-2008 | 04:53 AM
xbean's Avatar
Any day pics of a BSP?
Also can you buy a reflector piece that isn't amber? Like a clear one or something?
Thx...
Old 11-13-2008 | 05:47 AM
CIONIDE's Avatar
I think this is what you're looking for:
http://www.customxbgauges.com/index....7d26ae356da1b8
Old 11-13-2008 | 05:55 AM
xbean's Avatar
Wow this is exactly what I was looking for...thx
Old 11-13-2008 | 06:25 AM
CIONIDE's Avatar
I have to give the credit to DREWxB08, he found them during one of his all-nighters... that New Yorker never sleeps.
