Matching exterior white lights- what should i go with???
same in Hawaii, I think amber is the only legal color. I used to have white on my 1st gen, never got pulled over for the blinkers though. yellow is also a nice alternative, cops dont usually notice the difference unless its blinking crazy fast.
operatic has side markers?? someone tell me more. I have chrome bulbs up front and having that stupid amber on the side is annoying. so how do i get it off and replaece it. someone who got info come here n drop that ish.
I was gonna put leds in the turns but i didn't feel like buying a reisitor thing so they didnt hyper flash.
Clear side markers:
http://www.customxbgauges.com/index....7d26ae356da1b8
Here's a thread on it:
https://www.scionlife.com/forums/viewtopic.php?t=240170
You have to bake your headlights open to replace the amber with the clear.
You can deal with the tweaker flash by just adding load resistors. I'd solder and heat shrink the connections, though.
But this can! http://www.superbrightleds.com/pdfs/...istor_info.pdf
load resistors are horrific and get really frickin hot. just get a new flasher that supports led lighting
http://www.v-leds.com/BlinkerWarning...-p4481146.html
that one fits the gen2
I guess it all depends on what use each person values, and each states laws. I know you value the flashing lights when you use your remote, and that's great. In Cali it's not legal to drive with only your parking lights unless the forward facing turn signals can be demonstrated to serve as white daytime running lights. These dual turn signal bulbs serve that function for me, so I chose to give up the remote flashes in order to gain that additional functionality... plus they do look really good. :D
so... since i wont have the lights flash, is there a way to make the beep louder?
All I could suggest is maybe tracing down where the beep comes from, splice into the wires, use a relay, and use a horn you could scoop up from VatoZone or something like that.
Or even Pick-N-Pull.
SJMiller
09-12-2015 07:33 PM
