Cxr header installed
Old 10-18-2009, 05:36 AM
ScionFred's Avatar
I wish I could take that gasket off your hands but I'm sticking with the oem MLS gasket since my cast mani is very flat. The CXR turbo mani design is fine except for the use of thin 16ga 304 with no turbo bracing. Dezod uses 10 ga 304 and their log mani still cracks. I'm glad you like the CXR header. IMO, it's not hard to improve upon the oem header with it's crush-bent pipes, crushed into a small collector and restrictive cat. I'm quite certain that CXR beats Strup and W-R in hp per dollar if not bling factor and overall hp gain.
ScionFred is offline
Old 10-18-2009, 11:22 PM
renegade4x4's Avatar
Definetly agree we will se how it holds up though. My mileage got a nice boost. Past year same driving I have seen between 25.3 to 26.8 and this last tank was 27.4 so definetly better plus I wasn't driving conservative being that I have a new engine part. Lol. I made the company sent me another gasket because the one they sent me was bent so if anyone needs one I'm thinking 5 bucks shipped.
renegade4x4 is offline
Old 10-18-2009, 11:52 PM
strtrcril87's Avatar
Anyone have more pics of this installed????? The pics on cxr website don't show much.
strtrcril87 is offline
Old 10-19-2009, 06:25 AM
ScionFred's Avatar
https://www.scionlife.com/forums/sho...d.php?t=158907
Long thread but lots of photos.
Old 10-31-2009, 03:37 PM
Well after having this for 3 weeks I drove it fairly nice and only maybe 40 miles with air all around town and got 28.4 mpg!!! This is the same driving I always do and my best before was around 27.
Old 10-31-2009, 03:47 PM
elwaylite's Avatar
Fred,
Since I have the borla now, a header might be a consideration. I have no interest in removing the scuba (too noisy/it allows for retained back pressure), and am wondering your thoughts on the noise level after the header?
I am VERY happy with the sound and performance after the TRD CAI and the Borla axle back, so if the header offers more power, good, but if its "more raspy", then bad.
Thanks.
elwaylite is offline
Old 10-31-2009, 06:05 PM
ScionFred's Avatar
Originally Posted by elwaylite
Fred,
Thanks.
I really like the sound with a header, scuba and TRD AB. It's louder than stock but not enough to draw unwanted attention. I'll try to get a sound clip for you. A header should add 5-10whp/tq and the only time mine sounds a little raspy is at WOT near redline and between shifts. IMO it's well worth it unless you plan to go FI in the future.
W-R should net the most HP/TQ gains because of the 4-2-1 design and s-pipe followed by Strup, then CXR.
Old 10-31-2009, 06:09 PM
elwaylite's Avatar
Cool, thanks. Seems like the header would be a better investment than the Unichip. I have to pick my next $500 mod careful, because I'm moving soon, and once we get into the new house, I'm gonna drop $3-4k on a new 55" Sammy LED LCD
With the header, do you think enough back-pressure is still retained? I guess the axle back really does not change it much, just speeds up flow and adds sound.
Finally, did you install the header yourself? Does not look like it'd be too hard to unbolt and bolt the new one on.
Thanks
Old 10-31-2009, 07:26 PM
XD40tC's Avatar
If $500 is your limit it would be well spent on the MMW header for maximum gains. Then you could couple it with the Unichip later and get a nice solid tune for more gains. You should get cams and an intake manifold too! lol
XD40tC is offline
Old 10-31-2009, 07:35 PM
elwaylite's Avatar
http://weapon-r.com/english/index.ph...oducts_id=6336
$525
Old 10-31-2009, 07:48 PM
CIONIDE's Avatar
http://www.fastscions.com/Scion-xB2-...2008-2009.aspx
$446
CIONIDE is offline
Old 10-31-2009, 07:52 PM
elwaylite's Avatar
Thanks!
What is the deal with the "s pipe"?
Old 10-31-2009, 08:06 PM
CIONIDE's Avatar
Thanks!
You're welcome.
Search:
https://www.scionlife.com/forums/sho...d.php?t=127912
https://www.scionlife.com/forums/sho...d.php?t=152002
Basically frees up air flow by being larger and smoother than stock. I say just stick with the header first, you can always add the S-pipe later if you decide you want it.
CIONIDE is offline
Old 10-31-2009, 08:11 PM
elwaylite's Avatar
Hehe, busted being lazy!
Seeing as I would not use the S pipe, and the price difference, I think the Strup header might be better for me.
CAI, axle back and header come out to pretty good power according to import tuner.
Old 10-31-2009, 08:30 PM
CIONIDE's Avatar
NoLimitz sells both the Strup & Weapon-R headers, and has run them both on his xB2. His impression was that the Strup was better in the high rpm range, but that the Weapon-R provided more torque and power increases in the mid-range, which is probably much more useful for a daily driver.
https://www.scionlife.com/forums/sho...d.php?t=161949
Here's one more really good one for the S-pipe:
https://www.scionlife.com/forums/sho...d.php?t=148483
I think we have officially jacked this thread enough now.
CIONIDE is offline
Old 10-31-2009, 08:40 PM
elwaylite's Avatar
Thanks and agreed.
Old 11-01-2009, 03:59 AM
ScionFred's Avatar
Thanks
Sure, IMO you'll still have plenty of backpressure from the Scuba. The header is as easy to install as the axle-back, just more nuts and bolts. The only stuff I don't do myself is body work, paint, upholstery and auto trans rebuilds.
Old 11-01-2009, 10:43 AM
elwaylite's Avatar
Thanks!
Old 11-01-2009, 06:28 PM
ScionFred's Avatar
You're welcome. You'll need the front raised to reach the header to s-pipe spring bolts, use those ramps. Use a lot of wd40 and it's easier if you remove some of the heat shields from the oem header/cat. Make sure you have a 7/8", 22mm or O2 wrench. You can re-use the oem MLS mani gasket but you might want to replace it to be safe. About $35 from the dealer and the best gasket you can use. Have fun.
Old 11-01-2009, 06:42 PM
spiderxB's Avatar
anyone have a link to the cxr headers? What do they run?
spiderxB is offline
tckid21
03-12-2017 09:16 PM
SuBSiN
03-13-2015 04:02 AM
Frustratez
02-26-2015 04:03 PM
ofgarcia
12-22-2014 12:27 AM
TheRedBox
31
12-02-2003 04:53 PM
Quick Reply: Cxr header installed
