Feeler...cat back exhausts
Old 04-29-2010 | 09:28 AM
ScionFred's Avatar
I double-checked and the front s-pipe is double-walled but still 2.25" ID in and 2" ID out. The scuba tank is 2.25" ID in and 1.8" ID out, the mid-pipe is 1.8" ID in/out and the axle-back is 2" ID in tapering immediately to 1.8" ID. The TRD axle-back is 2.5" ID.
Old 04-29-2010 | 12:49 PM
Malibuguy's Avatar
wow...alot of ups & downs going on there
Old 05-01-2010 | 10:16 AM
ScionFred's Avatar
Yeah, I understand the progression from larger to smaller diameter to keep exhaust gas velocity up but the 1.8" to 2.0" to 1.8" transition at the axle-back confuses me. Even more when you add the 2.5" TRD axle-back to that 1.8" mid-pipe. I suppose that small dia exhaust piping acts similarly to a baffled muffler in terms of noise reduction and the TRD AB reduces back-pressure a little and adds a bit more sound.
Anyway, I hope there's enough interest to get this going. If you need a test mule, let me know. My exhaust is still a little loud for my taste and after you adjusted the front clearances, now it's hitting somewhere in back. Probably on the rear axle beam where CXR's fitment was also off.
Old 05-01-2010 | 12:47 PM
Malibuguy's Avatar
bring it in one day, i'll take a look at it...then we'll do the quad tips ;)
Old 05-02-2010 | 08:30 AM
ScionFred's Avatar
Yeah, I'll be bringing it to you soon. I really should have stuck to my original plan for a custom 2.5" but just had to try the CXR 3" because I found what seemed to be a great deal on a used system. If it wasn't too big, too loud and fit so poorly, it would have been a great deal.
Old 05-02-2010 | 02:00 PM
FromTheOld's Avatar
Just so you know, I'm definitely interested in buying a scubatank replacement section, so please try to do it if you can. Hopefully with the largest oval muffler you can find and with 2.5 inch diameter in/out
Old 05-02-2010 | 06:48 PM
CIONIDE's Avatar
Something like this, maybe?
http://www.aeroexhaust.com/index.php...k-muffler.html
Old 05-02-2010 | 07:31 PM
elwaylite's Avatar
Thats not bad.
1) Wonder how loud the car would be?
2) Would a normal shop replace the scuba since its a car?
Old 05-02-2010 | 09:21 PM
DREWxB08's Avatar
Im thinking about replacing the scuba with a 22" cherry bomb...........Direct replacement of corse.
Old 05-02-2010 | 09:23 PM
elwaylite's Avatar
Ouch. Holy loud batman!
Old 05-02-2010 | 09:28 PM
DREWxB08's Avatar
Yea i'm torn on the idea, I have the tsudo exhaust and i just love it, but just want a little more noise........ Cherry bomb could workout perfect or make it too loud..
Old 05-03-2010 | 01:26 AM
FromTheOld's Avatar
Originally Posted by CIONIDE
Aero is expensive, and not so good at muffling (compared to other standard means anyway). I will always stand by saying that the best muffler is one that uses stainless steel packing (either fully, or partially with high temp fiberglass/ceramic packing) and has large volume, which is usually an oval. AFAIK, that aero exhaust is round anyways.
Old 05-03-2010 | 01:53 AM
CIONIDE's Avatar
This part sounds like quality to me, and it seems to meet your standards as well, although I could be wrong:
"The 2525XL is completely stainless steel inside and out. A built in Resonator before our patented Air Foil is packed with high temperature ceramic packing. The hand-polished stainless steel 2525XL will give you the look and feel that you want and the performance you deserve. The Aero Exhaust Lifetime Warranty will guarantee that your investment is still performing as long as you own your vehicle."
And yes it's round (6" diameter), but at 26" long it would seem to have plenty of volume. Maybe combined with a quality axle-back it would give the desired tone. At $173 (best price I've found) it doesn't seem like a ridiculous price to replace the factory scuba tank. I'm sure a full custom exhaust could be had for cheaper than this, a new mid-pipe and axle-back, but I thought this might make an excellent starting point for a more mass produced scuba replacement piece. Just trying to think outside the box.
Old 05-03-2010 | 02:09 AM
elwaylite's Avatar
Will a muffler shop replace the scuba without resistance?
Old 05-03-2010 | 02:55 AM
FromTheOld's Avatar
It's not a bad choice, but on the cars I've seen with it (various cars, not scions though) it wasn't really too great with actually making things quieter compared to typical stuff like borla/magnaflow ovals, and either option is cheaper (easily under 170 bucks even for a big oval one). The advantage to the aero muffler is the fact that it is lighter than most options because it doesn't really use packing as it's way of muffling. It mimics the design concept of gun suppressors (or "silencers")
Old 05-03-2010 | 04:54 AM
GrahamO's Avatar
IF I do exhaust on my xB2, I want the whole kit and kaboodle. Whole shabang. If I have to pay a bit for it, I will.
Just like tattoos... Good work ain't cheap, cheap work ain't good.
lol.....you seem to like this kit and kaboodle phrase.
I'm on board for something like a high flow cat, but not make it really loud. I've got the Tanabe on now, and since it's broken in a little it is a little louder, but it could use a slight increase.
Old 05-07-2010 | 01:10 PM
FromTheOld's Avatar
How's the progress on this?
Old 05-07-2010 | 04:33 PM
Malibuguy's Avatar
i need a car to use for mock up...needs to be entirely stock
Old 05-07-2010 | 07:32 PM
ScionFred's Avatar
Can you use my stock exhaust pieces?
Old 05-09-2010 | 02:39 AM
Malibuguy's Avatar
i would want a fully stock car. Any exhaust modifications could possibly cause things to not fit other peoples cars
