My Homebrew CAI Version II :)!
Just to ask, why wouldnt you have made a true cold air and bypass the box? i know it has the filter but IMO i would've set it up with a filter at the end of the piping and have go straight into the TB, it seems like you just re made the plastic crap that Toyota put in which goes out of the OEM box. I'm not saying its a bad idea by any means, just think you should've run the piping through the whole thing and not have it dis jointed at the air box
If you look at the photos of the exposed PVC, you'll see I used two pieces of 3" ID PVC to give me approaching 90 degrees total, any error being taken up by the silicon adapters, especially the one at the TB.
You have to drill a hole and either cement a piece in or you can get a threaded/ glue in adapter to screw one in and use a rubber groumet. Just take your factory piece with you so you can get the right size for the vacum. autozone sells the silicone couplers for cheap by spectre, you will need 1 with a reducer and 1 straight. I would use a 45 bend drain pipe not schedual 40 its thinner and the size is right on the money. I bought all the stuff to do it but a guy swapped me his ingen cai for my trd drop in filter so back to the store it went lol.
The TRD part (not Toyota) is P/N PTR03-52084 and is named "TRD cold air inlet". It'll be a special order item, but try a dealer first. Note that this part only fits the 2008 through 2010 model years.
CrowJenkins
10-09-2015 10:47 PM
