View Poll Results: How much oil does your 2AZ-FE consume?
1 qt every 1000 miles
20.63%
1 qt every 2000 miles
14.29%
1 qt every 3000 miles
15.87%
1 qt every 4000 miles
1.59%
1 qt every 5000 miles
11.11%
Less than 1 qt every 5000 miles
36.51%
Voters: 63. You may not vote on this poll
Oil consumption
Old 05-14-2014 | 01:53 PM
  #81
elwaylite's Avatar
The simple fact is, if you do some periodic oil analysis on a weight for comparison, it'll tell you the answer. I get someone people cannot let got of 5w-30, but...
I've compared 0w-20, 5w-20 and 5w-30 in both my xB and Sonata. All performed well, so if I turned around and said "0w-20" is too thin, I'd be full of it.
Facts are facts. Now, once my Sonata hit around 80k miles it started to consume a little so I stepped from 5w-20 to 5w-30, and the consumption was greatly reduced, so the Sonata gets Mobile1 5w-30 and the xB still gets Mobil1 5w-20.
Old 05-16-2014 | 09:24 AM
  #82
TrevorS's Avatar
So 5W-20 remains your choice, how about that, it's my choice too! For those that prefer 0W-20W, more power to them (and good luck) !
Old 05-16-2014 | 12:35 PM
  #83
elwaylite's Avatar
Its my choice because it is the easiest to find in large containers. Nothing more nothing less, the "good luck" statement implies risk and is ridiculous.
You need to spend some time doing your own analysis or reading some oil websites. Facts are facts, problem is, most boards are riddled with "pulled out of my butt" or "was true 20 years ago".
Old 05-17-2014 | 04:22 AM
  #84
TrevorS's Avatar
Yeah, no doubt you're right, 0W-20 is surely the better choice! Engine tolerances are so improved there's clearly no advantage to the greater slipperiness of the heavier weight oils.
Old 05-21-2014 | 08:00 AM
  #85
stenger's Avatar
0W-20 with Mobile Syn and K&N oil filter. When you are winding out gears on the back road, taking 2nd/3rd gears out for long walks through the rev counter, you take few chances with "heavy" oil. More so in the summer.
Also I get better MPG with 0W-20 Syn/K&N Oil filter/K&N Air filter and 93 Octane than I do with conventional 5w-20/standard air and oil filter/89-93 octane.
Old 06-13-2014 | 09:32 PM
  #86
curtisc's Avatar
Here's a link to the class action lawsuit in regards to the oil consumption on the Scion xB and other Toyotas with the same engine. I encourage those with the problem to submit their names to the law firm:
http://www.carcomplaints.com/news/20...sumption.shtml
Old 06-13-2014 | 10:23 PM
  #87
xbscion's Avatar
Class Action suits will just make money for the lawyers. If the customers do get something it will be on the order of a coupon worth xxxxx dollars off of a new Toyota purchase. I'm not saying that people shouldn't go to that site and register with them, it's just unlikely that the owners will ever get their engines fixed.
Good Luck!
Old 08-30-2014 | 05:27 PM
  #88
RomScionXB's Avatar
Angry Oil Consumption
Good luck with this engine. Mine had no problems until about 62000 miles. I am suspecting the issue with the piston ring and the TSB will show up suddenly on almost all these vehicles. Anyway, one day while braking I noticed the oil light came on. It was a little more than 2.5 quarts low. After taking it to dealer they filled it and said to monitor it. Well it did it again, so they filled and said to bring it back after 1000 miles. Well at 250 miles, I check the oil and the dealer had OVER filled it by about a little over a quart! So i took pictures and documented every 250 miles. When I took it in it was about level. Then I showed them the pictures of it being over full at 250 miles in and they said that it was still in normal range. They said to check it again, this time, I had them check the oil level with me. I do have a Toyota extended warranty 'till 75,000 miles (It currently has 71,000 - that's how long this game with the dealer and Toyota has been going on!!!).
I almost never buy extended warranties, but since I like to keep my vehicles for 10 years, I thought it was a good idea and that this one would protect me since it was backed by Toyota.
If there is no resolution, there will be no more Toyotas for me sadly... and I was a staunch supporter when they were getting the bad publicity about sticking accelerator pedals and recalls...
More info:
Toyota and Scion Engine Oil Consumption ? Class Action Lawsuit - Chimicles & Tikellis LLP
My Vehicles:
2008 Scion xB Release Series 5.0
2009 Toyota Matrix XRS
2013 Toyota Prius
Old 08-30-2014 | 05:38 PM
  #89
RomScionXB's Avatar
Good Luck!
Unfortunately true. Experienced that before with other class action lawsuits...
Old 08-31-2014 | 10:07 PM
  #90
RomScionXB's Avatar
Originally Posted by Giantdefy
My 08 with 120k miles was burning 1 quart every 1000 miles using 5w-20. Switched to Mobil 1 synthetic 5w-30, surprisingly it stopped burning oil.
Great! I think I'll try that after this oil consumption test they are running.
Old 02-05-2015 | 01:54 PM
  #91
Roller_Toaster's Avatar
So, my xb (I thought) completely eats oil.
Running 0w20, I burn at least a quart every 1000-1500 miles.
I've been running thicker oil to try and counteract this, and it has helped a bit.
But...I just changed my oil yesterday. I had been running 5w20. Three thousand miles on it, dipstick was completely dry.
I decided that before taking it in, I would get ahold of a friend of mine who is a toyota tech and see what he thought.
He was very aware of the situation, and told me not to take it in yet, as it would not qualify.
Seriously? Burning two quarts of oil in three thousand miles isn't "excessive"?!?
I don't doubt that he knows what he's talking about, he actually told me to keep driving it and to bring it in in a few months, in case the oil consumption has increased.
As is though, I apparently won't qualify, and it will be logged that I don't qualify.
Old 02-06-2015 | 05:54 AM
  #92
RayScionXB's Avatar
Busted my Engine and had it repaired after they had a technician go and see the car from headquarters and confirmed that the damage to the engine was from lack of lubrication But again the person at the maintenance said i was lucky since i have always done all my maintenance done with Toyota here a link i found
Excessive Oil Consumption on 2AZ-FE Engine LSC ZE7 | TOYO Headquarters
Old 02-19-2015 | 03:43 PM
  #93
olecarguy's Avatar
Default 95K - No Oil Burning
2008 XB, Auto, 94.8K miles, religous 5K changes with Mobil 1 0-20, Fram filters. Less than .5qt lost between changes, and this .5qt loss was only on last 2 changes starting at 85K.
yupinmytC
22
07-27-2024 08:08 PM
mudguy
10-22-2015 05:31 PM
crimson_sinn
09-25-2015 10:41 PM
Klashan
09-24-2015 01:39 PM
vi3tb0i09
09-23-2015 09:32 PM
