Ordered My CXR Header!
I received a coupon for ebay, 8% off so I have been looking at this and have read the review that one member made and I too am going to try it out. I will let everyone know how it goes! I am going to put header wrap on it so if anyone has ideas on what wrap to get and where i can get it that would be great! Thanks!
Chris
Chris
ScionFred had to do a lot of work to his CXR header just so he could bolt it on:
https://www.scionlife.com/forums/sho...d.php?t=158907
The whole heat wrap thing is controversial. Some say it's bad, some say it's good, and some don't care. It keeps heat in better than anything else, but to somewhat correct previous posts, it's not because the gas temperature increases and causes it to crack, but it's because the heat has nowhere else to go but stay inside the wrapping. Also, some say it speeds up the rusting process because the moisture has nowhere to go after the car is turned off, but there are debates on that too. While it is stainless steel, believe it or not, stainless steel does rust depending on the grade. It may be 304SS, but you never know with stuff like that, because you don't know the quality of the metal. Then there's the question of the welds. They look sloppy, and there's no way to know if they're good without other forms of looking at it (IE: X-Ray)
I don't want to keep going on and on, but you bought a cheap part, so you shouldn't be too worried about it. Wrap it like you wanted to and enjoy it. If it cracks or whatever, just put the stock one back on. I doubt you'll notice much more power anyway, and you didn't spend much on that header so you won't be set back too much. For the record, I've got nothing against China, etc, but there is a reason it is cheap. Manufacturing costs, material costs, lack of R&D, etc.
Good luck.
Chris
Chris
IMO as long as you take the time to check flange flatness, correct it as necessary and use the proper gasket, you'll be very happy with the 5-7whp gain and much improved exhaust note. The CXR header isn't the best header available for our cars but it does offer the best bang for the buck. I've got well over 5k on mine now and it's holding up just fine. If you wrap it, it will probably crack. I'd recommend leaving it unwrapped or having it creamic coated. There seems to be some confusion about the heatshields on the oem header/cat. They do not reduce underhood temps. That heat has to go somewhere and it remains under the hood. By removing the primary cat, a header alone likely reduces underhood temps.
Good luck and I hope you enjoy it.
http://cgi.ebay.com/ebaymotors/Scion...Q5fAccessories
as far as a heat coating goes, Id say have it jet hotted. Jet hot is a brand name of a company that thermal coats exhaust and other parts. check them out... after that you can find someone local to you that can do something close.
-nick
-nick
hampton1100
01-02-2015 08:13 PM
dinkjs
35
01-13-2004 11:55 PM
