Strup Header
Old 04-05-2010 | 03:32 AM
fireyrguns's Avatar
Default Strup Header
So i installed my strup header yesterday with the weapon r cel elim. Have a ? at first it smoked for a bit and smelled like gas really bad. Is this normal? today it didnt smoke at all but off and on it smells like gas a little yet. This a normal thing till the computer adjust to the header? No cel came on as of yet so we will see.
Now my other issue i have a rs7 with the TRD muffler. I was hoping that installing the header would make the exhaust note a little better but dang hardly no diff than what it was. I have friends with tc's and trd mufflers that sound great and a friend with an xd and a trd muffler that also sounds great whats the deal with this muffler!!!
Old 04-05-2010 | 03:34 AM
Murphys_Law's Avatar
its new and hasnt been blown to crap yet with exhaust gasses???
Old 04-05-2010 | 05:10 AM
jonathan110987's Avatar
smells cause the metal of the header is getting hot for the first time
Old 04-05-2010 | 08:11 AM
ScionFred's Avatar
The smoke is normal, the gas smell could be an exhaust leak. My TRD muffler sounded great with a header but maybe you want it louder? If so, you need to delete the "scuba tank" with a straight pipe and hi-flow cat.
Old 04-05-2010 | 11:47 PM
miketf1's Avatar
i have the strup and the trd exhaust. it constantly smells like gas. without the main cat it doesnt filter anymore so it will smell that way. i only smell it at a cold idle.
as for the trd muffler there is a minimal difference and thats normal because there is a very large resonator/muffler in the mid-pipe. take it out and it will be louder.
Old 04-06-2010 | 07:18 AM
ScionFred's Avatar
Just remember to install a new cat if you remove the scuba tank. Running around without any cats is irresponsible. Besides, if you remove the scuba tank, you'll need something there or it will be too loud. A hi-flow cat will sound as good as or better than a resonator.
Old 04-07-2010 | 02:33 AM
fireyrguns's Avatar
You guys are great !!! Thanks for all the info ...
Old 04-12-2010 | 02:53 AM
XD40tC's Avatar
Your car should get a little louder over time. I remember when I installed 2 different exhausts on my tC it sounded completely stock for the first day. And then the next day it was very noticeably louder and sounded nice. Your increase in exhaust flow from the header will "break in" your TRD muffler even more.
Old 04-12-2010 | 03:02 AM
fireyrguns's Avatar
Yup it's starting to sound a lil better already.
Old 04-16-2010 | 03:41 PM
mudvayne2k6's Avatar
Unique Scionikz
I wanna the strup header but i live in cali and what do i do about removing the origi al cat will i have to remove the scuba tank and replace it another cat? What about the 02 censor with that go on the header?
Old 04-16-2010 | 04:53 PM
streetxdreamer's Avatar
The scuba tank cat does not get removed. The upper cat on the stock header is deleted.
There are 3 OT sensors, one before the first cat, one after the first cat, and one somewhere by the scuba
the first O2 just needs to be put on the header. The second you will need to use a cel eliminator
Old 04-17-2010 | 03:45 PM
touring's Avatar
Are you using an s pipe? If not, you should be
Old 04-17-2010 | 06:10 PM
ScionFred's Avatar
Actually there are only two O2 sensors on my 08. The primary wide-band AFR sensor in the header and the secondary narrow-band O2 sensor in the s-pipe.
Old 04-17-2010 | 10:35 PM
fireyrguns's Avatar
And why should i be using an s pipe?
Old 04-19-2010 | 01:09 AM
TrevorS's Avatar
Yeppers, a lot louder ! I agree with "ScionFred", don't straightpipe it, you need something in there for emissions, and also to tame the sound.
Old 04-19-2010 | 07:53 AM
ScionFred's Avatar
FYI, the mid cat/resonator (scuba tank) ain't the biggest problem with the stock exhaust, IMO. It's the 1.8" ID pipe between the scuba and the axle-back. I used to think it was 2.25" until I removed it, then I guessed it was 2" until I measured it. Why 1.8" instead of 1.75" I don't know but I measured it with calipers so it is what it is... way too small.
Old 05-01-2010 | 01:18 AM
fireyrguns's Avatar
So i see the cxr S pipe on ebay for 99.00 but its 3" will this help or should i stay stock s pipe?
Old 05-01-2010 | 01:22 AM
touring's Avatar
+1
Old 05-01-2010 | 02:04 AM
Mouse's Avatar
Here's my 2 cents on your post... so don't take this the wrong way... but if you live in Cali... I wouldn't put a header on your Scion. I've got a few good friends out in CA and they've said that the cops really crack down on emissions violations. You change your header therefore deleting the primary cat... I've heard of lots of horror stories of monster expensive tickets for modding a car like that in CA. Honestly, what most of us do to mod our Scions for more HP pretty much makes them non-street legal in most states in the country... but CA cracks down the hardest. Hell, if I moved to CA I'd turn my tC back to stock as far as my performance mods go. It ain't worth the hassle or cost IMHO.
don't hate... just tossin' that out there to maybe save you a big chunk in tickets/fines.
Old 05-01-2010 | 02:09 AM
Mouse's Avatar
Stay stock. or at max 2.5" diameter. From what I've seen, 3" and up are generally only for FI/turbo setups as far as tC's go. My setup is a N/A and Im 2.5 all the way back into a 3.5/4" tip at the muffler itself (Injen SES).
