Switching to eneos?
Switching to eneos?
I have recently talked to someone who said switching from normal convential oil to a synthetic would be bad for my engine? I am currently at 30k mileage. Do you think it would be bad? Who else has done it and at what mileage? Should I take it to the dealer? That way I can pin it on them if any problems?
At 30K you should be fine, not enough gunk built up to cause any problems when it clears out. Now if you do it at 80K like I did with my Odyssey then you can have leaking seal problems.
DeepSouth Scions
You can switch from conventional to synthetic and back at any point. Anyone who tells you different is full of ****. I've personally done it with no issues on the xb2. You can switch to synthetic at your first oil change if you wanted to. www.bobistheoilguy.com
At your mileage its fine. What can happen is, conventional oil sludge is cleaned off at higher mileage when someone starts using syn, and the seals have hardened and can cause oil leaks. Most of the time it's ok to break the engine in on conventional, then swap to syn.
Now, on the subject of Eneos, hell NO! It's a way overpriced Group III, and not worth the dough. Im a member of a subscription blog (costs money per year and has a NDA) by a guy in the oil industry and someone who is well respected on BITOG. Your best over the counter options are Mobil1 0w-20 or Pennzoil Ultimate 5w-20, and Mobil1 or Purolator filters.
Second, since you appear to be interested in and knowledgable about oil, have you seen any actual evidence that Toyo changed any bearing clearances when they changed the oil spec from 5w30 to 0w20? I haven't found anything. DezodDon posted up some bearing specs from an older turbo engine spec'd for 20w50 and 5w30 spec'd TC 2AZ-FE bearing spec's. They were the same. Don even recommends 10w40 for boosted 2AZs.
I recently flushed out the low viscosity Toyo WS ATF and replaced it with standard viscosity Mobil One syn ATF. The only noticeable difference is that it shifts a little more firmly and the torque convertor hooks up better. Again I couldn't find anything to suggest that Toyo changed anything in the U241E when they changed the ATF spec. IMO the WS ATF is a big part of the reason our AT shifts are so "slushy". I've recently had a chance to drive a 2001 Corolla with 100k miles on it and it's AT filled with oem Dexron-II shifts like a AT should. Nice firm shifts with no "slushy" feel. IPT only uses Amsoil standard viscosity ATF in their built ATs, regardless of what Toyo recommended.
Until proven wrong I'm of the opinion that Toyo changed both the motor oil and ATF specs for improved fuel economy and emissions reasons only.
Ps; I know it's not entirely accurate to lump ATF into only 2 categories (standard and low viscosity) but excluding type-F, all the recent ATF formulations fit pretty neatly despite small viscosity variances between different spec's and manufacturers.
I was under the impression that the engine got more piston squirters at some point, but Ive not heard anything on bearing tolerances.
My oil analysis on the Hyundai 2.4L (calls for 5w-30 and 5w-20) on 0w-20 Mobil were gorgeous, and thats from Terry Dyson. I've not done one on the xB yet, but its coming. The 0w-20 oils are top quality fluid, and I see no reason why they cant handle a NA engine. The Mobil 0w-20 meets the Corvette Gm high perf oil spec.
Now on a FI car, I cant say either way, and in my opinion, can no one else. Only way to prove or disprove is with a professional oil analysis after running it in your setup. One reason Im running the Redline 0w-20 now, because it uses some of the best basestock you can buy.
On the WS, I cant say because of the NDA, but I will I'll continue to run it, and just change every 30K. It is not good for 100k, I dont care what they say.
You can switch as much as you want, at whatever mileage you want! I wouldnt recommend using synthetic after 100k if you havent been using! The reason being, and this will sound retarded but, synthetic oil has smaller molecules so its more prone to leaking! I know all of this because ive been to 2 different oil plants! Youll definately be fine switching though!
Start from the beginning with syn. If you have a high mileage car, just use some High Mileage (which is a blend and will clean the engine but also has seal conditioners)
All my new vehicles in the last 10 years have had a couple of 3k mile break in changes, then full syn for the rest.
I wouldn't bother having the dealer do it, it's just an oil change.
The cost was bad but not horrible. Ended up with leaks on the rear main seal, oil pan, and later on the front seal. Since I had some other work to do at the time I was able to cut some of the costs down by combining the work. Also helps that Jason(scvscion) is my mechanic.
What might a UOA tell me about 5w30 vs 0w20? Assuming both oils are the same quality, differing only in viscosity range, all I can imagine is additonal cold-start wear with thicker oil. However, I can't see that being a problem except in very cold climates.
Before changing WS for M1 syn I contacted IPT and M1 tech support. IPT said all they use is Amsoil std vicosity syn ATF and the guy at M1 said that although they can't officially endorse their multi-vehicle ATF as WS compatible, he didn't know of any reason not to use it. If I'm not mistaken M1 makes WS for Toyota NA so that might be a factor as well as the slightly thicker viscosity of M1. I'll see how it works out for me.
Machbox: I hope you're not running 0w20 with the turbo! DezodDon knows more than I do and likes 10w40 but I'd still go with 5w30 full syn considering where you live. I'm running 5w30 in the winter and 10w30 the rest of the year, right or wrong.
Biggest thing is, a 5 or 10w-30 has a higher HTHS than a 0w-20, or 5w-20. It's been seen that a HTHS of 3 or more (30w), as opposed to one less than 3(20W) holds up better under punishment, and engine design.
Other than cold start wear, which is one of the big times you have wear, is that the lighter weight warm oil (20 vs 30), actually pumps faster therefore it picks up heat and carries it away faster. Faster flow across a hot surface will keep the surface cooler than slower flow, at least thats what the experts say.
Redline 0w-20 has a HTHS of 2.7, while their 5w-20 has a 3.3. I've thought about moving to it, because thats a 5w-20 that acts like 5w-30. Their 5w-30 has a HTHS of 3.8
Here's ya a good example of how weight doesn't always matter:
Spec--RL0w20--RL5w20--RL5w30--Mobil5w30--Mobil10w30
HTHS--2.7--3.3--3.8--3.09--3.14
Noack--9--8--6--Mobil does not give it, but usually 8-10
Flashpoint--216--251--252--230--224 (Celsius)
Viscosity 40C--43--55--62--65--62
Viscosity 100C--8.2--9.1--10.6--11.3--10.0
Viscosity index--166--145--162--169--147
Redline's 5w20 is superior to Mobil's 5w30 and 10w30 in almost every way.
Now their 5w-40 has a HTHS of 4.6!! A NOACK Volatility of 6 and a Viscosity Index of 170. My whole point to this junk is, don't necessarily look at oil weights, but their specs.
HTHS over 3 is good for abuse, 3.3 or higher is better
NOACK (lower is better) - determines the evaporation loss of lubricants in high-temperature service. The more motor oils vaporize, the thicker and heavier they become, contributing to poor circulation, reduced fuel economy and increased oil consumption, wear and emissions.
Viscosity Index - Lower number here means that as you drive it harder, it'll thin out more with heat. Higher number better
Finally, yeah you wanna make sure your 100C number is in your 30w range, but that varies. Thicker the better, in your case, maybe. Thats where the oil comparos come in.
Hey Fred, I did some more reading, and I don't doubt you on FI and 40wt. You really should look at the Redline 5w-40
API Service Class
SM/SG/CF/CJ-4/CI-4
Viscosity Grade SAE 5W40
Vis @ 100°C, cSt 15.1
Vis @ 40°C, cSt 94
Viscosity Index 170
Flash Point, °C 250
NOACK Evaporation Loss, 6
HTHS Vis, cP @150°C, ASTM D4741 4.6
It kicks the crap outta the Mobil 40w specs.
API Service Class
SM/SG/CF/CJ-4/CI-4
Vis @ 40°C, cSt 94
Viscosity Index 170
Flash Point, °C 250
Well, if I were typically any lighter on the throttle, I'd probably get a ticket for holding up traffic at lights. I'm presuming Mobil One 5W-20 is fine for my N/A engine. Cost IS a factor!
Haha, you have nothing to worry with 0w-20 or 5w-20 Mobil.
FI cars need the hvy-weight-when-warm-oil, and I'm talking to folks now about oil recommendations. Now that Im modding, and have moved from 2000-2500 rpms shift to 3000-3500 rpm shifts normally i may need to change ;)
Good point about fluid flow rates and heat absorbtion/dissipation. However, a fluid can also move too fast for optimal heat transfer. One example would be removing your thermostat. Removing that flow restriction can actually lead to overheating if the coolant passes too quickly to acheive optimal heat absorbtion in the engine and dissipation in the radiator (oil pan). Again we're back to the too thin vs too thick vs just right dilema.
M1 10w30 has a HTHS of 3.14 and 5w30 is 3.09. With any luck, it will be "just right" for my application. The best I can do is make educated guesses...
Good dialog man. I learned some things from it.
