TRD (xB2) CAI Installation Order
I need a quick word of advice from all you TRD CAI owners, if you please. I was about to pull the trigger and order the $299 kit for my '09 xB from TRDSparks.com when I noticed a small note in the installation instructions. It says the "recommended sequence of [TRD accessory] application" is: 1) the CAI kit and, only then, 2) the front strut tower brace. Below this note is the cryptic notation - "* Mandatory".
So, since I just installed my TRD front strut brace and don't feel like pulling it out again, can someone tell me if it really will somehow obstruct the installation of the CAI if left in place?
Thanks, Marc
(Oh, and if you're feeling really generous with your time (someone?), could you tell me if I really have to "drop the front bumper" or pull the front, left inside fender liner every time I want to inspect the CAI air filter. If this is indeed the case, then it'd be an absolute show-stopper for me. Accessibility is everything! Thanx again, M)
Thanks, Marc
Yeah, I know, you're right. I worry too much. But with just two 10mm nuts securing the plastic engine cover at the FRONT end, why does TRD even mention a strut bar installed to the engine's REAR? (And then say "Mandatory"?)
Anyway, thanks.
Anyway, thanks.
Of course.
However, I followed the TRD strut bar install instructions to the letter, which involved removing the wiper motor cowl/assembly, etc. - not just four nuts, and I don't relish doing it again. But, as you say, it is roughly below my strut bar where my intake plumbing resides.
I value the knowledge I've gleaned while lurking here on SL and was hoping to elicit a comment from someone to the effect that I could still manage the job without difficulty (i.e., without removing the strut brace).
Anyway, the point is moot because I ain't gonna fit a CAI if the consequence is that I can't whip open the air filter enclosure whenever I want. I don't mind getting on the ground to do it but unbolting and/or moving other stuff out of the way first is a "no go."
Thanks very much again.
Marc
Marc
I put the strut brace on before installing the CAI. You can indeed install the CAI without removing the strut brace. It will make the install a little tougher as the strut brace does get in the way.
You DO have to take off the wheel well liner to get to the airbox/air filter of the TRD CAI. This may kill the deal for you.
Check out the K&N CAI. The filter is located in the engine bay so you don't really get cold(er) air, but it is more free flowing than stock and it is easy clean/replace.
DeepSouth Scions
Take off the bumper if you are installing the CAI. I removed mine when I removed the snorkel off my stock intake. It makes things much much easier and the bumper is stupid simple to remove and reinstall.
Removing the bumper is definitely the easy. Removal of the bumper is a hand full of 10mm bolts, a couple quarter-turn fasteners, pull by the headlights, and it's off.
I don't personally own the TRD strut brace, but I couldn't see it inhibitting much while installing the intake. At all, really.
Should fit fine.
Thanks all:
I've gotta think on this - $300 is a lot of money for me (if I were to go TRD). And IF I do make the purchase, the installation will occur through the space left by the front bumper!
M
(The only thing I REALLY wanted for my car was the supercharger, sigh ...)
M
ive had the trd cai from the beginning and yes you do have to go thru the fender or bumper to check/clean the air filter Truely stupid, but i just converted mine to short ram and kept on truckin
id would recomend just buying a different brand that fits your need and is easier to maintain TRD aint all that jmo
hampton1100
05-28-2015 07:32 AM
TheRedBox
31
12-02-2003 04:53 PM
