View Poll Results: When did your water pump fail?
0-25k miles (please explain)
2.63%
25k-50k miles
26.32%
50k-75k miles
7.89%
75k-95k miles
7.89%
95k + miles
7.89%
My pump failed more than once (please explain)
2.63%
My pump hasn't failed yet (25k-50k miles)
15.79%
My pump hasn't failed yet (50k-75k miles)
21.05%
My pump hasn't failed yet (75k+ miles)
7.89%
Voters: 38. You may not vote on this poll
Water Pump Failure Poll
Old 03-16-2012 | 04:33 AM
ScionFred's Avatar
Default Water Pump Failure Poll
This poll is intended to collect factual data on the XB's actual water pump failure rate. Your vote is public so others can see how you voted. Please vote honestly and don't use this poll for other agendas. TIA.
Old 03-16-2012 | 05:44 AM
CIONIDE's Avatar
2008 xB had the tell tale sign of the pink line on the underside of the hood, leaking pump confirmed by a Toyota tech at the dealership, and then replaced under warranty at 47,239 miles. We'll see how the 2012 does.
Old 03-16-2012 | 06:31 AM
TeeCizzle's Avatar
what my waterpump looked like after taking it out...
Old 03-16-2012 | 12:38 PM
Thermos2003's Avatar
I have a 2005 tc but also have the water pump problems. I'm only posting because I believe it is the same engine and water pump. Failed the first time at 49,000 miles. The second at 81,000. It was covered the first time under warranty. The second time it was a $300+ bill.
Old 03-16-2012 | 01:09 PM
lefty29er's Avatar
Replaced two One in the '08 , one in the '09 , both under warranty.
Old 03-16-2012 | 02:22 PM
MeatRocket's Avatar
had mine replaced on my 2007 tc at 36k on my 2006 tc at 54k and my 2009 xb at 34k lol. lets hope they last lol.
Old 03-16-2012 | 02:54 PM
XPRESSCION's Avatar
That's crazy....
How one model has huge problem while other models with same motors aren't getting this problem as little to none.
I have put 235k on a tC. I never once had this problem.
Since I just bought a 12 box: I hope I have the same luck.
Old 03-16-2012 | 05:51 PM
ThatGuyAtGeweke's Avatar
Mine started leaking bad at about 60k, right before i started my engine build. At 52k miles, not one drop.
Old 03-16-2012 | 05:53 PM
Also it really does not matter what car you have, all water pumps connected to the 2.4l and most of toyotas are not the best in the world. I have stated on here before that if toyota has one fault its their water pumps. I work for toyota have for 5 years so i see why they come into the shop. However i would rather have a 150 Fix vs thousands and if thats the worst thing i have to worry about im laughing.
Old 03-16-2012 | 07:42 PM
MeatRocket's Avatar
this^^^ both my tc's and xb have the 2.4L
Old 03-17-2012 | 04:29 PM
NocturnalxRS6's Avatar
My pump just started spraying on the under hood, 57k.The dealer said it is not leaking enough to be replaced at this time.
Old 03-17-2012 | 04:39 PM
CIONIDE's Avatar
If you have the pink line under your hood, then it needs to be replaced. Go to another dealership, or call Scion so that they can instruct the dealership you went to on filing the warranty claim.
Old 03-18-2012 | 05:44 PM
dead on, i work for toyota and this is covered at any point when it starts leaking. Take it to a different dealership and call and complain about that one.
Old 03-18-2012 | 09:43 PM
YELOSUB's Avatar
Wagonistas
Any way to add vehicle year to poll? I (should say the wife) has the 2010 RS7 xB and have not heard about anyone with that particular year with a water pump failure...
Old 03-20-2012 | 06:23 PM
isomswim's Avatar
I have noticed a WHITE line under my hood, passenger side. Not PINK but it troubles me figure I should take it in just to be safe. Coolant is a hair low but haven't ever noticed a coolant smell. 2009 w/45000miles
Old 01-25-2013 | 03:29 PM
ajski's Avatar
At dealership right now. 2009 Series 6.0. Replacing water pump under warranty. Tell tale sign of white powder streak under hood. Pink crystallization inside pulley and water pump area. 46,700 miles.
Old 02-09-2013 | 05:19 PM
JoeSpeed's Avatar
Default '08xb
Never had problem at almost 147,000 miles.
Old 02-12-2013 | 05:28 AM
Mauby's Avatar
Water pump failed today @147. First time since purchasing my baby. Much...much easier than my '02 V6 Passat. Getting one from Pep Boys tomorrow.
Old 02-12-2013 | 06:59 AM
Metalcoffin's Avatar
Mine had let a little coolant out around 30k but hasn't ever since...or at least my coolant level is ok and there's no splatter from it under the hood.
Old 10-14-2024 | 09:33 PM
RobNugent's Avatar
Way late to the party on this one!
Failure at 223,000!
Also, now have water in the #3 cylinder ...
Going to try and pressure check each cylinder with a gauge to see if it is only the head gasket. This seems to be an issue when the pump completely fails and dumps all the water while traveling on the highway.
Anyone's experienced this? Pointers or ideas?
Griffin00420
07-22-2017 11:15 PM
boostedrs1
01-23-2013 08:54 PM
aromero101
10
01-13-2013 09:00 AM
JohnnyBfromPeoria
10-03-2009 05:16 PM
Taknitez
07-22-2009 12:31 AM
Quick Reply: Water Pump Failure Poll
