DELETE
I wish there was away to override the "auto downshift" when you were in sport shift mode, or whatever it is called.
Congrats, it sounds FIERCE!
Are you using the base turbo, or did you get an upgraded one?
I wouldn't mind seeing a printout of your boost levels vs rpm :D
ill try to get that dyno run scanned and then posted. I spent so much time yesterday getting my stock parts organized at my storage, I must have packed it away along with my manuals for the FIC.
Im not sure why toyota opted for the "sport shift" mode, as a simple PRND2L would have sufficed.......in actuality, it is not a true sport shift, It simply allows you to downshift to that gear. If the ECU detects your RPMS will be too high (5k to redline), it will not let you shift into that gear. If you are heavy in the throttle and shift to say 3rd, the ecu will downshift anyways to 2nd. Extremely frustrating as the ecu essentially controlls all shifts!!! WTF??? The only thing the ecu wont do is upshift you to the next gear, should you hit the rev limiter.......I dont see how that is any benefit?????
Dyno with an auto is a PITA already, but the scion "sport-shift mode" made it an even bigger Pain!
I'm looking for options but coming up empty thus far...
http://www.powertraincontrolsolution...mildetails.php
AFAIK 08-12 share the same shift console.
Sorry to hear about your issues but hopefully they can be corrected pretty easily. Although the P0420 can be "tuned" around, it can't be tuned out. It's easier to fix the problem than hacking the tune to correct for it. Besides which you won't pass an emission test with a CEL present or pending.
Contrary to popular misconceptions, the ECU does use the 2nd O2 sensor as a check against the primary AFR sensor and uses this info to make small corrections. Since the ECU expects to see exhaust gasses that have been burned again in the primary cat, the easy solution is to reduce the volume of gas sampled by the sensor when the cat is no longer present (header or turbo).
What kind of anti-fouler/spacer did Descendant install on the 2nd O2 sensor? I'm a big fan of the 90* angled CEL eliminators. They reduce the volume of exhaust gas measured by the O2 sensor and can further be tweaked by rotating their orientation to fine tune the CEL out. WR, Strup and Big Daddy's Garage all offer good ones in 304SS so they won't rust away quickly like the cheap plug anti-foulers do.
IMO the first step is to eliminate the P0420 CEL and see how it runs. There are likely some tune issues as well but I'm sure Chruches can sort those out. Another thing that comes to mind is that the engine always idles faster after a battery disconnect and doesn't settle down for a while. If there were a idle problem with the tune, it could be masked every time you disconnect the battery and then appear when the ECU eventually lowers the idle speed again.
Good luck and feel free to PM if you have any more questions.
I've never seen a P015A before. I wouldn't worry about it unless it keeps coming back since it may be related to the recurring P0420. It is my understanding that the ECU may adjust the AFR a little based on the 2nd O2 sensor. For example if the 2nd O2 is reading too rich the ECU may lean the AFR a little and compare readings between the primary AFR and secondary O2 again. The 2nd O2 reading rich won't cause major issues but it could contribute to your lean-AFR stalling issue. I suggest installing a proper anti-fouler ASAP as it can only help.
The back firing is just a tune issue that Churches can sort out. Although
back firing during a shift is normal. The ECU pulls a ton of timing during a shift and I often get a "pop" from 1-2 and 2-3. They can probably tune out the stalling too even with the P0420 but IMO you still want to get rid of that code. 8psi and 270 whp/wtq is a good place to be with an auto. I was talking to Justin from P-Tuning at the car show sunday and he told me the same thing Toan did about "built" U241E trans... "Don't do it!". He said they've seen nothing but problems from them.
I wouldn't reset the ECU before the tune. Let the tuner see the codes and other issues firsthand. Let him decide if he wants to reset before tuning. Good luck!
Here's a good explanation of the P0420 DTC from Toyota:
http://www.ncttora.com/FSM/2003/Repa...fe/cip0420.pdf
This DTC is a 2 trip detection logic code meaning that the CEL will come on during the 2nd trip (ign on/off cycle) following a reset if the problem is present. During the first trip it should show as pending and then after you shut down and restart, the CEL will appear shortly afterward.
I don't know of any connection between idle speed, the CEL setting and subsequent stalling but that doesn't mean there isn't one. Fix the P0420 and at least you can scratch that off the list of possibilities.
You are correct. The ECU does raise the idle speed with A/C on and also adds some AFR enrichment. I should mention that I too have a lean idle issue in warmer weather and turning on the A/C helps. Even my idle fuel trims are unusual. With 20% larger inj's I have idle LTFT of 0 where -20 is expected. My LTFT crusing at 60 mph is -19 as expected. My theory is that the actual IAT is colder than the sensor reads because the hot intake air at idle is cooled by the IC. Since the actual IAT is colder than the ECU thinks, it requires more fuel. IMO this is the main reason why many prefer a blow-thru MAS over a draw-thru. IAT is a very key element for the ECU to calculate air density and the fuel required. However while this IAT discrepency caused lean idle issue isn't ideal, it isn't a deal breaker. I can't remember the last time my car stalled because of this, if ever.
the good> churches agreed with you, in that the second o2 sensor does have the capability to respond with the 1st, and tell the ecu to modify the afr's, which is probably what is happening. No matter how hard the tuner modified the fuel trims at idle, the car would fall on its face at idle, or under hard deceleration. He monitored that although he instructed the FIC to be richer at idle, the stock ECU was cutting fuel trims, hence the conflict/contradiction (probably due to the CEL). he suggested either:
A) the '11 AUTO had a change in the ecu and descendant might want to look at this closer in regards to what has/hasnt changed in ecu trims from 8-10 to 11+ AUTO's.
B) The second o2 sensor is modifying the afr's at idle, and as a result, is overriding my tune, and screwing with the trims, per P0420 code.
A is possible but IMO very unlikely. I agree with you that B is the more likely cause. One more thing to check is the BOV. Although it's recirculated, I've found that a partially open BOV can still cause idle problems, even when recirculated. What is your vacuum at idle? Mine is 20-22 in hg.
With the P0420 code being out of the mix, this *SHOULD* clear up the stumbling issues at idle/decel.
That's what I'm hoping for. If not there's still a few possibilities including the BOV setting, another vacuum leak or maybe even the inj dead time setting in the FIC map.
can you say definitively that there were no changes made on the ecu for 11+ autos? although robs car is also '11, he is a M/T and is not experiencing these probs, nor did he have a need for the o2 sim. This is why im assuming this is strictly Auto related?? you would know better than me and the tuner at this point lol
No, I can't but I very much doubt that your problems are caused by a ECU change. I bet Rob has a larger exhaust that reduces the gas sample presented to the 2nd O2 sensor. He also doesn't have torque converter load on the engine at idle. Hang in there, Bro! Boosting the auto XB ain't easy but it can be done. You'll get there and enjoy the hell out of it when it all gels.
my TRD boost gauge does not read below 20in hg, so im not sure if my actual readings are below this or not....interested in how you can read 22 in hg?
come to think of it, I thought that my vaccum readings were a little high, but I did check all piping for vac leaks to no avail.
Ive enclosed some pics with readings from my gauge. Keep in mind that this was 5 miles after a battery disc , which right now my idle is fine because I imagine the ECU is relearning yet again. let me know if you think my readings are a little high, as they have always been since I took delivery of the vehicle
pics in order:
Park Idle>Park Idle w A/C>Drive Idle>Drive idle w A/C
the drive with ac concerns me the most as this reading is rather high 18inhg. This could be due to the fuel trims the tuner modified, or the ecu reset, nevertheless, they seem rather high.
pics in order:
If you're between 0-1000' ASL like me, your engine vacuum might be a little low. It's too close to be sure but you could have a small vacuum leak. Small vacuum leaks have their greatest impact at idle when intake air volume is at it's lowest. A small vacuum leak can cause a lean idle condition and stalling. You should mention this to Descendant. Since they installed the kit using cheap hose clamps, they should verify that you don't have any leaks with a leakage test.
FWIW, I hate cheap, un-lined worm-gear hose clamps. The only clamp possibly less reliable is the wire spring clamp. Even oem wide-band spring clamps are better. T-bolt clamps are worth every penny. If I bought a Descendant turbo kit, before even installing it I would substitute T-bolt clamps for all the hose clamps. Then I'd never have to worry about vacuum leaks.
Not to say that you can't acheive a leak-free setup with cheap hose clamps, because it is possible. It's just more difficult and less likely.
Either way, It's not heat that causes a P0420, it's not enough oxygen in the exhaust gasses. When the primary catalyst is removed the secondary O2 sensor reads a richer (low oxygen) AFR because unburnt fuel from the primary combustion process has not been re-burned by the catalyst. The O2 sensor compares oxygen levels outside the exhaust to levels within the exhaust gasses. The reason for spacing the o2 sensor further from the exhaust gasses and reducing the gas volume it is exposed to make it read a higher oxygen concentration in the exhaust gas by reducing the sample size only on the exhaust gas side.
In fact, by removing the primary catalyst, exhaust gas temp at the secondary O2 sensor should be reduced.
I'll have to have them look at this issue tomorrow, as they will be installing the O2 sim anyhow, so they can take a look. Then I have retune appt immediately afterward.
Given the info sp2 has provided I guess it's safe to say, we've found the prob. I was just under the impression that I was nit-picking this, but seems I'm not alone. I hope this thread has served its purpose as a guildeline for autos looking to boost and precautions, if anything.
O2 fix and Redyno tomorrow and that should be the end of it. I will have a follow up with dyno sheets.
I appreciate your input as well as sp2.......now I understand that the xb2 FI section really is pretty dead! A shame given the mass market in the tC section lol
Maybe you can just suggest to descendant that you suspect a small vacuum leak and ask if they can test for one? A small leak could certainly explain the lean idle and stalling issues. Although as I said, I hate cheap worm-gear hose clamps I must admit that once you acheive a leak-free seal with them, they probably won't leak again if left alone. Well, except for coolant hoses that expand and contract a lot but that's another issue.
Good luck tommorrow and I sincerely hope everything gets sorted out 100%. You're very welcome, I'm glad I could be of some help.
I'm happy to hear that things are getting better. Did you ever find out what your elevation is Above Sea Level (ASL)? Specifically where you were when you took those pics of your vacuum readings? At 500' ASL I'm pulling 22 in hg and your vacuum seemed a little low, suggesting a possibly leak. However if you're at 2500' ASL, your engine vacuum would be the same as mine.
To adjust the BOV, remove the recirculation hose and cap the opening on the intake pipe. With the hose removed you should be able to see the valve inside the BOV. At idle your BOV should stay closed. It shouldn't flutter or move at all. If it does tighten the spring preload until it stays firmly closed, no more, no less.
You might consider replacing the hose clamps between the turbo and TB with T-bolt clamps. Hose clamps are fine for the air filter to turbo inlet. If you order them online they're pretty cheap and work a lot better. Good luck and enjoy.
well unless Rob added exhaust last couple months,
when picked my car up in May after gauges and boost controller install, Rob took me for test drive in my car, he said was a beast compared to his with stock exhaust, haha
glad everything is working better for you now
My elevation here in SoCal is anywhere from sea level, but no more than 1000ft max, so pretty much the same as you.
I did talk to Decendant today, and they did state my vac levels were perfectly normal for this kit.....furthermore they claim back levels vary from vehicle to vehicle.
I did reclamp all my hoses, and found one attached to the intercooler that is a bit stripped and needs replacement. If this is related to the stall issues, I doubt it, but I will be replacing it tonight.
Also I'll attach pics of the bov that I took when I dismounted it. It looked normal, however I Will admit I didn't know exactly what to look for. As well, I am not sure how to inspect for a vac leak, any pointers is appreciated as always.
Bottom line is that there is no more cel and the car pulls hard and strong. The stumble at idle issues is irritating, but nothing that won't be fun trying to chase down.
I've always said that the hiatus of a build is taking on unexpected problems, and readapting/reapplying your route. What fun would it be if everything went as textbook as possible all the time????? Lol
As for the BOV, here is a good read:
http://www.frozenboost.com/stpg.php?page_id=bov
Technically you have a bypass valve since it's recirculated and shouldn't have the same vacuum leak effect when open at idle but I have the same setup and it idles much better with the BPV closed during idle.
Anyway, I'm glad you're enjoying the boost and hope the idle problem gets resolved soon.
I'm not sure what else to suggest. Did Descendant install new spark plugs? Copper or iridium? Copper ND plugs didn't work very well for me but 1-step colder NGK Iridium IX pre-gapped to 0.032" work great.
Here is a DIY for a boost leak test in case you need it:
https://www.scionlife.com/forums/sho...oost+leak+test
Good luck and keep me updated on this. I'm very curious to know what the cause and solution are.
