Dezod/APR X1 support group
If you have one, you already know we need this. I'll start... does anyone know how to manually modify the default software installation so that I can save tune changes without getting an error code referring to an incorrect path? (XP and W7) How about data logging? Everytime I try to datalog the software crashes.
How do you save to a new file name? How do you save to an alternate location?
Please feel free to post any questions or answers regarding APR X1 usage as well as your own results and impressions of the unit.
Me too! Thanks. I'm sure this will work but at the moment I'm trying to work out some software bugs. Whenever I make any changes and try to save them, I get this error msg (W7 and XP):
I tried creating the folders specified in the above error msg since the software installation didn't but it still doesn't work. Also odd is that the path in the msg is not the path to the cal file the X1 loads at startup.
The long and short of it all is that we needed software revisions to make the tC work. I had got with one of the writers there, and ended up getting it done. The V3 runs the Tacoma and FJ stuff.
I suppose you mean the X1's internal software (firmware) since the only available version of Xtune is .03A from APR's website (AFAIK).
BTW, my Xtune gauges don't work anymore. Xtune sees the X1 but that's all. I'm going to try going back to the original Main DAQ file and see if that works.
I don't have any experience with the program your working with; however, i've run into similar problems with black box equipment. I had to use one program on my desk top to change and save files then clear the memory off of field equipment and reload the altered file. Some programs allow you to monitor and download data and give the appearance of allowing you to change base files then reject the changes. Other programs then allow you to manipulate data and change base conditions but have no ability to communicate with sensors.
Luckily the X1 and Xtune aren't like that. It turns out that my initial file saving problems were a simple folder name error and the more recent problem was fixed by re-flashing the X1. Apparently I have to be careful about using my OBD2 scantool with Xtune. Using both together caused Xtune to freeze and screwed up the X1 programming. I tried re-flashing it tonight per APR's instructions and it froze at 4% several times. Then on a hunch I disconnected my OBD2 scantool and the X1 flashed first try. Everything is working 100% again.
I'm using a ELM327 clone and Palmer ScanXL Pro software.
Everything is working now and I can use my OBD scantool with Xtune and I can synch but I can't flash the X1 with the scantool connected. I can only guess but maybe the scantool was bridging power to the X1 or feeding 5V USB to it which would have prevented a successful flash. The APR manual says that a "stuck" X1 needs to be powered down for 2 minutes before being re-flashed.
In a nutshell, me not creating all the necessary folders with correct naming before using Xtune caused a lot of problems. I've probably grown too accustomed to more typical Windows programs that do all this for you during the installation. I think everything is good to go now.
Weird is right! I'm only speculating on what event caused the X1 to stop working but I think it had to do with disconnecting the USB cable while Xtune was frozen. Xtune used to freeze whenever I tried to create a data log but I discovered this was due to not having a 'stc24' folder in the APRdata folder (note that the '.X04' folder name suffix is not required for this folder).
I will. BTW, I should at least mention that I love your AFR map and the X1's ability to provide those target AFRs perfectly all the time. It's so much more consistent than the FIC and pulls harder without any annoying little hiccups. Oh yeah, not a single CEL or even a pending code.
Gadget from URD describes the X1 as "self-tuning" and IMO he's right on the mark. At least after the correct initial settings are input. Great product!
BTW Paul, what scantool do you use? Hand-held or PC based?
Send me a datalog and I will see how well you are doing.
